02-25-2022, 09:35 AM | #1 |
HokieV
68
Rep 55
Active Blind Spot Detection Not working consistently
I have a one week old 2022 X3 M40i and during my first extended drive this week noticed that the Active Blind Spot Detection light on the right side does not consistently work.
I have not been able to determine any patterns. Does not seem to mater the vehicle size, color or shape nor the speed I or the adjacent vehicles are going. Does not matter if it is raining or not. Left side works fine. I would guess that it only works properly 10-20% of the time. Any suggestions prior to taking it in and letting dealer determine the issue. Sample video below. https://www.youtube.com/watch?v=eJsJ2V_M1IY |
02-25-2022, 11:02 AM | #2 |
928
Rep 2,046
Drives: X3 G01 30i xDrive
There are many limitations to the system. The first mentioned in the manual is "if the speed of the approaching vehicle is significantly higher the own. " And another - the boundary lines have to be clearly visible, wet conditions are also a limitation I guess in your case these could have an impact to the functionality.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
03-12-2022, 08:52 AM | #3 | |
HokieV
68
Rep 55
I am now wondering if one or more of the sensors is not working and these two problems are related. Not thrilled with having to bring to a dealer due to distance to closest one and having to deal with probably leaving there and transportation to and from. Anyone know others having an issue with the Active Park Assistance not working on an new 2022 X3 M40i? |
07-28-2022, 09:16 AM | #5 |
Rep 4
2022 X3 blind spot problem - on the passenger side this sensor doesn't not work consistently. BMW is not commenting other to say that the passenger side does not operate if the speed differential is too great. I have tested this and it does seem to work some times if the speed differential is very small. But it is way different than the drivers side which works 100% and I consider it a safety hazard. Not sure what BMW is thinking with 2 different calibrations. I also have a problem with the the auto tail gate opening sensor - works about 10% of the time. This is a nice car but these types of problems on a new vehicle are very annoying -especially when there is nothing the dealer seems to be able to address to fix. Also have a 2019 Mazda CX5 signature - no problems - blind spot works perfectly-- and comfort, size and drivability vs X3 are at least equal maybe better. Tough justifying $15k more for the BMW. Actually tried to get another Cx5 signature but wait time was too long - BMW X3 had quicker availability. Think I know why now.
07-28-2022, 09:21 AM | #6 | |
HokieV
68
Rep 55
07-28-2022, 10:38 AM | #7 |
818
Rep 2,869
Put your blind spot warning detection on “early”
BMWs system is picky about how fast you might be passing someone. I thought mine was messing up too, but it’s just how the system works. Putting it on early detection does help… some. Try that… It could be a bad sensor but that is very uncommon but not impossible |
07-28-2022, 10:52 AM | #8 | |
HokieV
68
Rep 55
07-28-2022, 03:26 PM | #9 |
925
Rep 1,213
Drives: 2022 BMW X5 45e M-Sport
It sounds like it is working as intended per the manual snippet below.
You're seeing it on the left when cars are coming up from behind and pass you. You don't see it as often on the right because you are generally passing those cars, unless they decide to speed up and pass you then you'll see the warning. |
07-28-2022, 03:47 PM | #10 |
Rep 4
thanks - I think the manual snippet is referring to the absolute speed of travel not the differential speed. In other vehicles with blind spot warning sensors there is a warning whenever there is a car in the blind spot - right or left - period. Anything short of that is a safety concern and for sure can not rely on lack of warning on the passenger side of my BMW - very possible there is a car in the blind spot.
07-29-2022, 08:48 AM | #11 | |
HokieV
68
Rep 55
07-29-2022, 09:13 AM | #12 |
332
Rep 379
Drives: 2022 X3 M40i AW/TacRed
Mine detects every time a car is back on either side. It is reflected in the graphics in the cluster as I have that option enabled. When a car is passing or being passed the graphic reflects this condition in the cute little animation. I had steering intervention enabled and if I try to change lanes while blind spot is active the car aggressively corrects me. This has since been disabled.
I have noticed a few quirks with some of these automation systems like parking and ACC. But for the most part they work as expected. If the OP is not getting the parking yellow, amber, red distance warnings something has to be wrong with sensors… no?
2017 530i (G30) - Mineral White
2022 X3 M40i - AW/ TacRed |
07-29-2022, 09:50 AM | #13 |
Rep 4
Apparently - this is a problem beyond the X3 - I found this review on X5 with same problem:
Blind Spot Detection problem of the 2021 BMW X5 Failure Date: 01/25/2022 This is a 2021 BMW X5 with BMW's blind spot warning system. The vehicle currently has approximately 5,500 miles and was purchased new. The blind spot warning system has consistently malfunctioned since the vehicle was delivered. When monitoring the right side (passenger side) blind spot it only picks up on average 1 of each 3 vehicles encountered and completely the ignores the the others. By "picks up" I mean the visual indication in the right side mirror is lighted when the vehicle is in the blind spot. For those the system does not detect there is no visual indication of the vehicle and if the right turn signal is activated there is no warning of the vehicle in the blind spot. This effectively renders this critical safety system completely useless and a serious safety hazard as it is clearly malfunctioning. Upon complaining, the X5 was inspected by the dealer who reported that no malfunction was found and the system "is functioning as designed". After additional discussion with the service manage the dealer verbally admitted the system was not detecting other cars on the right side of the vehicle consistently but as there was no electrical fault detected in the system, it must be ok and it was not a repairable issue. Assuming the dealer's analysis of the problem is correct, this leads to the conclusion there is a serious safety design flaw in BMW's blind spot detection system. A brief examination of various BMW related internet forums shows this issue, or very similar issues concerning the function and design of the BMW blind spot detection system have been reported by several BMW owners, suggesting the problem is likely a design flaw and not a simple component failure. |
07-30-2022, 12:28 PM | #14 |
928
Rep 2,046
The system is working as expected and designed by the manufacturer. It doesn't mean that it works as expected by the customers. Same goes for every software/app/program.
AllBlackBimmer817.50 |
07-31-2022, 11:56 AM | #15 |
4495
Rep 7,539
Ditto above…this appears to be a misinterpretation or expectation by some owners…that assume the system should work a certain way…perhaps from experience in other marques. But it specifically says it does not operate like they expect in the owners manual. Passenger side only illuminates when a car in that lane is “APPROACHING”. If you passed that vehicle…then the light doesn’t come on…unless they begin to speed up and move into your “blind spot”…or you slow down and it causes them to move into the blind spot.
But if one is using their turn indicator prior to changing lanes…if there’s a car in the “blind spot” and it is UNSAFE to change lanes…you should get vibration in the steering wheel and the light will illuminate…even if the light wasn’t illuminated prior to the attempt to change lanes. As posted above…the operational parameters of the system was explained for when the light illuminates on the passenger side. It DOES NOT illuminate just because a car is there if it is not overtaking you (“approaching from behind” as written in the owners manual). But if you were to SIGNAL and the car is in this blind spot…you should get an alert. (Try it the next time you think the system isn’t working because the light is NOT illuminated but there’s a car in the lane on the passenger side that is NOT approaching from behind but is just in the lane next to you…activate your turn signal to see if you get a warning). Now…if you are not signaling (as many assume BMW drivers don’t)…then you may not get a signal or warning if YOU passed them. But if they begin to approach you (speed up into this area)…then the warning light should come on. Or again, if you actually SIGNAL to move into their lane…you should get the light and vibration warning.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-31-2022 at 12:02 PM.. |
AllBlackBimmer817.50 Usachampion189.50 |
08-01-2022, 12:59 PM | #16 |
70
Rep 276
My experience from owning Audi and BMW vs some other Japanese and American brands is that if I'm passing a car quickly no blind spot light is going to come on.
Other brands might show a glimpse of light as the vehicle in momentarily in your blindspot. Same scenario but pass the car but slower and give it more time to hang out in your blind spot you will see an indicator. Blindspot monitor isn't going to alert you each time because if you're passing someone you should know from basic driving skills they should be next you. However, if the vehicle decided to match your speed and linger, you will get an alert. If a vehicle is slowly approaching, no indicator will display until they're actively in your blindspot similar to other brands. What sets this apart vs some other brands, if vehicle is approaching quickly, even if they are 150ft away, the blindspot warning will illuminate as that could be a potential threat if you were to change lanes in front of that car. The other brands don't measure speed differential and will wait until they car has entered your blind spot in which imo it's too late. Safer and minimizes false alarms
'16 BMW M3
'16 BMW X5M '23 X3 M40i (On Order) '21 Civic Type R |
08-05-2022, 08:43 AM | #17 |
Rep 4
All good comments. I tried Subzeros suggestion about signaling to see what happens. Pulled along a tractor trailer on the passenger side (no signal) and put on right turn signal - no warning light or vibration.
08-09-2022, 05:42 PM | #18 |
70
Rep 276
Did you try matching the pace of the semi?
'16 BMW M3
03-27-2023, 07:14 PM | #19 |
38
Rep 322
I believe these issues can be fixed with Bimmercode Expert mode. The BSM speed differential must be greater than 5-7 mph, so by the time the other car enters your blind spot as you are overpassing, the amount of time it takes for your car to change lanes would mean the car would no longer be in the blind spot collision course by the time your car enters its lane. Just to reduce false positives I assume.
There must be a way to code the speed differential to be less so the BSM activates more often, and also should be a way to code BSM activation speed to 0 kmph instead of 20 kmph. Useful when trying to pull out of a parallel parking spot onto a busy road or merging back from the highway shoulder when it's hard to keep eyes entirely focused on the blind spot and make sure you don't crash into anything in the front. Has anyone successfully done that? Last edited by thepianist1; 03-27-2023 at 07:20 PM.. |
