02-22-2022, 04:50 PM | #1 |
93
Rep 203
Starting climatization from app activates steering wheel heating
Every time I start climatization from within the app, steering wheel heating is also turned on.
This happens even when outside temperature is around mid 70s and I have steering wheel heating activation set at below 55F. Note that this doesn't happen when scheduled climatization rules kick in, it only happens when I press the climatization button on the iOS app. Am I missing a setting somewhere? |
02-25-2022, 08:57 AM | #3 |
43
Rep 80
02-25-2022, 12:42 PM | #4 |
407
Rep 626
My heated steering wheel always activates with remote start as well, with both the app and key fob. I wonder if this will continue to happen in the coming Spring/Summer.
02-26-2022, 12:05 PM | #6 |
13548
Rep 20,186
It depends on what version of iDrive you are using. It has been going back and forth for a few years now as to whether the remote start does the seat heating. I think for the last few major versions it does. I have 11/2021.50 and the seat heater comes on (only tested with touch and not a thermometer). The lights signifying the heating do not though until you hit the Start button.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
02-26-2022, 12:51 PM | #7 |
167
Rep 74
Drives: 2022 BMW G05 X5 M50i
Same issue with my ‘22 M50i (steering wheel heat turns on). I’ve also noticed that although the A/C is set to 72 or 74, the air temperature always feels much warmer when I get in the car after a remote start has run for 5-10 minutes. I thought maybe I had put in wonky climate control rules, but nope. They look fine. No idea how to fix this??
Seat heating (or ventilation) comes on after I get in the car and push the starter if the outside temp is lower/higher than my rule. Not sure what software version I’m on, but it says it’s up to date (no updates available). |
02-26-2022, 01:14 PM | #8 |
4718
Rep 8,780
Drives: eVeRyOnE mAD!
you'll have to go into your iDrive remote software upgrade section to see which version you have. note, it's almost always a few months behind the most recent version due to rollout lag
02-26-2022, 08:24 PM | #9 |
91
Rep 130
You can set steering wheel heating activation using the climate control rules app.
22 BMW X7 M50i
24 Porsche Macan GTS 24 MB GLS 580 (wifey) 23 Countryman JW Cooper (wifey) |
