02-15-2022, 05:49 AM | #1 |
BMW Enthusiast
175
Rep 221
Coding Fix For Dimming Due To Tint!!!
I know that the dimming dash has been a long time issue for many with tinted windows. There has been a coding fix posted in the main thread but I thought that it needed it's own post over here. I can't take credit for this but I can confirm that it is working on the G20s. Here it is...
It can be done in Bimmercode expert mode... Headunit 3005 APIX_CID_UND_ZIN DIM_CURVE_X2 change values to 0x00, 0x00 (from 0x1F, 0xC0) Instrument cluster 3000 Anzeige_Konfiguration DIM_TAG_NACHT_LICHT_EIN_ENABLE change value to aktiv Instrument cluster 3005 FuBi_Parameter DIM_DTN change value to 0x7F (from 0x3F) After programming the codes above, go to Car/Settings/Displays/Control display and change the “Brightness at night” to it’s lowest value. Then use the standard I.P. scroll wheel to set a comfortable light level in darkness. |
14
02-15-2022, 08:00 AM | #2 |
119
Rep 230
So you had daytime dimming issues due to tinting, and this fixed it? What is the end result for daytime brightness? The dash still dims up and down, but the overall brightness level is higher? It's a bit confusing that the fix references night time dimming…to my knowledge night time dimming has never been an issue as it's always been manually controlled.
02-15-2022, 09:21 AM | #3 | |
BMW Enthusiast
175
Rep 221
With the above coding it's now bright during the day, dimmed down at night and controllable with the scroll wheel. |
02-16-2022, 10:52 PM | #5 |
117
Rep 219
Drives: '19 G20 330i & '19 G01 X3
I'd pretty much given up on a fix for this. Hope this works! I have a new M40i I was hesitant to tint because of the problems with my 330i.
euro_syd1.50 |
02-20-2022, 08:00 PM | #7 |
Rep 29
02-21-2022, 08:20 AM | #9 |
17
Rep 33
I coded this yesterday on 2021 M340i with 11/2021 software and it works as described.
Note that it is not required to turn down "brightness at night" all the way down. This will still control "additional" brightness of the iDrive screen ONLY relative to the physical brightness dial (next to headlight controls) position. Turning "brightness at night" all the way down effectively makes the iDrive brightness match the cluster brightness, but if you want extra boost on the iDrive brightness, you can still use "brightness as night" for this purpose. |
euro_syd1.50 |
05-05-2022, 05:19 PM | #12 |
652
Rep 826
Drives: 2021 BMW X3 M
The scroll wheel on the driver's side actually works now! Thanks for this!
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
05-06-2022, 12:42 PM | #14 |
Rep 1
Just coded mine and set brightness to high but dash is not as bright as befor, but does not dim anymore which is good lol. Now to just get that dash brighter.
06-02-2022, 09:29 AM | #16 | |
1399
Rep 2,221
Can you explain if this is a different fix and how it impacts the control screen? I would love to get my cluster at the same brightness but don't want to make the control screen dimmer. |
06-12-2022, 06:57 PM | #17 | |
Rep 28
This did not fix the issue for me idk why. When I was driving today the cluster was still dim. When I flashed a light into the IR sensor then it went bright again. |
06-12-2022, 07:05 PM | #18 |
5547
Rep 4,079
Did BMW ever fix this issue in the 2021/2022 models? I see more people complaining that have a MY20 (like I had with the same problem).
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
06-22-2022, 01:16 PM | #20 |
Rep 10
Coded this myself this morning and went driving around for about an hour between sunny and cloudy weather and it seems fine now. Manually toggling the headlights on and off and it seems to dim correctly. Thanks!
10-09-2022, 08:43 AM | #21 |
37
Rep 55
Drives: M5 Competition 2019
10-09-2022, 09:23 AM | #22 |
652
Rep 826
Did you actually save and code it?
