01-19-2022, 07:56 PM | #1 |
249
Rep 1,051
X5M 21" Competition
Anyone run the 21" X5M competition wheels on a G05?
X5M Comp front: 10.5Jx21 ET31 (P/N 36119502648) X5 Rear 21" 10.5Jx21 ET43 (P/N 36118071999) ???
2023 X5MC | Donington Grey | Black
01-19-2022, 08:32 PM | #2 |
718
Rep 1,452
Yes, people have put the 809s on the G05.
https://g05.bimmerpost.com/forums/sh...postcount=2866 Would have to confirm size and offset.
No. Try not. Do. Or do not. There is no try.
-Yoda |
02-26-2022, 02:38 PM | #3 |
Rep 62
I got the 808M wheels for winter. 10.5J in front and 11J rear. I'm even using a spacer (12mm) on the rears but non for the front as the wheel is almost sticking out a bit. Happy to send pics if u want.
02-26-2022, 03:38 PM | #4 |
96
Rep 183
04-08-2022, 08:45 AM | #6 |
Rep 14
Thanks
i;28635756]Here you go[/QUOTE] Is there no rubbing on front when turning? My current summer setup on X5 M-Sport package is: Front: 9.5x21 275/40R21 ET37 Rear: 10.5x21 315/35R21 ET43 Would love to go with 808M winter package Front/rear: 295/35R21 10.5x21 ET31 That said Front would have wider rim and wider tire and 6mm diff in offset. Both Front and rear will be sticking out more that i understand just worry about the front clearance. Thanks |
thezarb14.00 |
04-08-2022, 06:45 PM | #7 | |
718
Rep 1,452
I had the same thought as you for my G05, but wanted to know if anyone experience rubbing. I was thinking of doing a square set-up with the 809s or 818s.
-Yoda |
04-08-2022, 07:32 PM | #8 |
718
Rep 1,452
what tire size are you running front/rear?
-Yoda |
04-09-2022, 05:50 PM | #9 | |
Rep 14
295/35R21 10.5x21 ET31 From what I read so far it's the most popular setup 295/35 and will fit the G05 M Sport package. Last edited by mikeavs; 04-13-2022 at 03:03 PM.. |
05-06-2022, 09:24 AM | #10 |
718
Rep 1,452
How did the fit turn out on these?
-Yoda |
10-23-2022, 12:10 PM | #14 | |
124
Rep 208
I was eyeing 285/40/21 because its only a 1% deviation. The tires are a lot more expensive though. |
10-23-2022, 04:06 PM | #15 |
718
Rep 1,452
Have you seen selection in 285? I'm piecing together my winter set now and have only come across the 1 in stock recently for 285 size, Vredestein Wintertrac Pro, also smaller select in general of tires. 295 has several more tires and brands to choose from despite the 1.7% diameter difference from stock size (I'm running 22s), but more importantly their isn't a difference between front and rears. Speedo will be off a bit, but the bigger concern with Xdrive is the front/rear difference.
-Yoda |
10-23-2022, 07:00 PM | #16 | |
124
Rep 208
10-24-2022, 06:42 AM | #17 |
718
Rep 1,452
Did you square your set-up or just planning to use OEM rims with square tires? DWS is a great tire but doesn't come in a 285 as far as I'm aware (had an off forum discussion last year with a group of car friends about tire selection and lack of all-season choices on with the staggered 21s).
-Yoda |
11-11-2022, 07:58 PM | #19 |
Rep 14
How did you end up without spacers on front. As soon as I mount the front wheel, the rim touches the control arm and its entirely stuck to the point I can't spin the wheel. There is no clearance at all. I had to go with 15mm spacers. I could probably go even with 17 or 20mm to clear it even more.
11-11-2022, 08:02 PM | #20 |
Rep 14
Yes, the rear is fine no problem. However, for the front I needed the 15mm spacers to clear the space between the rim and the control arm. The 808M rim is wider than the original summer rim 10.5 vs. 9.5 and once the front mounted it touched the control arm entirety to the point I wasn't able to spin the wheel.
11-12-2022, 04:14 PM | #21 |
Rep 62
No problem on my end with the front wheels. Cant even imagine using spacers in the front as the wheels are already a bit wider than the fender. I got them from the aftermarket so maybe different from OEM 808m but still 10.5J and 295x35x21.
11-13-2022, 06:55 AM | #22 |
Rep 14
That's very interesting. They must be different than yhr OEM 808M. The offset must be different or the thickness of the rim. I had to use the spacers no other way around it. Glad it worked out well for you.
