What's Your Best 60' Time?
11-26-2008, 12:48 AM | #1 |
46
Rep 502
Post you best 60" Time with a pic of your slip if you have it.
Since getting a good launch is so important to 1/4 mile times, I was curious to see what kind of 60' times other 335i drivers have run at the strip. Note if you were running the stock Run-Flats or another tire, post the brand, size & psi. Plus any mods. Here's mine. My E93 is a real heavyweight at almost 4,000 lbs. That may be why I was hooking up so good but quickly ran out of steam. As you can see my Trap Speed was on the slow side due to the weight I guess. 60' Time: 1.77 Transmission: Step Tires: Stock Run-Flats w/8,200 miles on them @23psi Perf. Mods: JB2HR & U.R.Coated DP's w/ Stock Exhaust /100 octane Amount of Gas: 1/4 Tank of Gas Weight: Empty 3,995 lbs.w/out Driver 220lbs.Total 4,215 lbs.
"WorldsQuickest 335i E93"
SMART-Top /One-Off Opaque Vinyl EYELIDS / 30% TINT / A.C.SCHNITZER Pedals / "M" Tri-Color Wheel w/Paddles / EIBACH Pro-Kit / AKEBONA F. & EBC RED-STUFF R.Dustless Pads / Drilled & Slotted ROTORS / MIRO M6 Reps / MICHELIN PS2's / U.R.Coated DP's / CYBA-QUAD Exhaust Tips / BMS-TUNED... |
