Bimmerpost
4 Series
Marketplace Vendors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons N54Tuning.com - NEW Competition 4.5" Catless Downpipe B58 Engine (G Chassis) - G20
      01-10-2022, 12:53 PM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
BIMMERPOST / Classifieds
Asking Price:
USD 490.00
Item Interest
Competition Series 4.5" Catless Downpipe B58 Engine (G Chassis) - G20
ORDER LINK
https://www.n54tuning.com/competitio...ssis-p630.html
SKU: BM-EXH018
Our Competition Series 4.5" Downpipes for your 2020+ M340i six cylinder B58 turbo engine!
Key Features:
Fitment for the new BMW B58 Engine
Higher Max Horsepower Power Curve
Higher Intial Torque Curve. Torque curve hits faster, higher, and longer
Better throttle response and faster turbo spool up times
Mandrel Bent 4.5" piping. Smooth transition to the exhaust system
100% Stainless Steel Construction
100% TIG welded for better quality welds
Precision CNC machined turbocharger V-Band flange
Brush Finish (standard) or optional Polish Finish
Available with high temperature Black Thermal Coating to reduce underhood temperatures
Optional - Additional O2 sensor bung for wideband O2 sensors (comes with pre-installed plug)
Optional EGT sensor bung for EGT gauges (comes with pre-installed plug)
Compatible with the factory or aftermarket exhaust systems
Track tested durability
Includes all hardware for complete installation
Limited Lifetime Warranty
Restrictions in the exhaust system robs horsepower and torque especially on turbocharged cars. Thus, removing as much exhaust flow restrictions will increase horsepower and torque significantly. The factory catalytic converter found in the factory downpipe is a big culprit of this and is a major exhaust flow restriction. The factory catalytic converter is made up of catalyst material formed into "honeycomb" weaves. Exhaust gas must pass through these tiny "honeycomb" weaves on their way to the exhaust system thus causing a major exhaust flow restriction. It also causes turbulence after the catalytic converter which causes the exhaust flow to slow down (which increases restriction). By replacing the factory downpipe/catalytic converter with our Competition Series 4.5" Catless Downpipe, more power is unleashed!You will feel the difference instantly. While the 32whp and 16wtq gains are awesome, one of the best aspects of the downpipe is that the gains are not just peak gains. Examine the dyno graphs and you will notice the powerband shifting to the left. What this means is that turbo lag is reduced with power coming on faster. Gains are throughout the powerband as well. Your car will feel like a totally different beast. As if it had woken from it's sleep!
SO WHY 4.5" PIPING? The new turbochargers on the B58 engines utilize a much larger 4.5" outlet compared to the 4" outlet on the older N55 engines. If we ran a 4" downpipe flange inlet so that we can use 4" tubing, a "step" would be formed between the turbocharger outlet and downpipe inlet. Exhaust gas for the turbocharger would hit this "step" and a lot of turbulence would form at this point and cause backpressure. Backpressure this close to the turbocharger would greatly affect performance. Thus, to ensure that we get unobstructed flow from the turbocharger outlet to the downpipe inlet, we had to CNC machine a new 4.5" flange to match. This allows a seamless transition and eliminate any possible turbulence which would cause backpressure. Though this presented another challenge for us as 4.5" tubing is not readily available and hard to source. Our motto "Performance, No Compromise" prevailed at the end and through hard diligence and many phone calls, we finally found a source for the material. Even though the material was considerably more expensive than standard 4" stainless steel, we wanted to give our customers the best by producing the best product possible.
      01-24-2022, 11:53 AM   #2
Mike@N54Tuning.com
4918
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
Mike
      02-14-2022, 02:12 PM   #3
Mike@N54Tuning.com
4918
Mike
      02-22-2022, 01:33 PM   #4
Mike@N54Tuning.com
4918
Mike
      02-26-2022, 10:18 AM   #5
Mike@N54Tuning.com
4918
Mike
      03-07-2022, 04:37 PM   #6
Mike@N54Tuning.com
4918
Mike
      03-21-2022, 11:58 AM   #7
Mike@N54Tuning.com
4918
Mike
      04-18-2022, 03:15 PM   #8
Mike@N54Tuning.com
4918
Mike
      06-15-2022, 01:26 PM   #9
Mike@N54Tuning.com
4918
Mike
      07-26-2022, 10:59 AM   #10
Mike@N54Tuning.com
4918
Mike
      11-01-2022, 08:47 AM   #11
Mike@N54Tuning.com
4918
Mike
      01-18-2023, 12:48 PM   #12
Mike@N54Tuning.com
4918
Mike
      05-24-2023, 11:02 AM   #13
Mike@N54Tuning.com
4918
Mike
      09-27-2023, 05:21 PM   #14
Mike@N54Tuning.com
4918
Mike
      01-16-2024, 12:35 PM   #15
Mike@N54Tuning.com
4918
Mike
g20
