F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > Fault 440101 xDrive
Studio RSR
      12-30-2021, 02:29 AM   #1
Merlino31
Merlino31's Avatar
Italy
Drives: BMW f31 320 modern
Fault 440101 xDrive
Goodmorning,
my mechanic has in his workshop a f31 320d xDrive from 2014 which has the fault 440101 Transfer box (VTG) End of transmission service life reached.
He checked the VTG ratio and the rear diff and are both at 2.81.
Clutch pack of xDrive are fine.
Mechanically is everything okay but he couldn't delete the error.
Any solution?
BMW f31 320d Modern 6MT
      12-30-2021, 05:55 AM   #2
Tommi_Mav
Greece
66
Drives: F32 435dx
Originally Posted by Merlino31 View Post
Goodmorning,
Any solution?
I'm not an expert and I don't really know if there's such option, but maybe try to register first that he installed a new transfer box (without actually replacing it). This way, the ECU will reset the value and then delete the code. Something similar with what you do when DPF is clogged, but you just clean it and register that you put a new one.
      12-31-2021, 02:47 PM   #3
Merlino31
Merlino31's Avatar
Italy
Problem solved coding the DSC and another ECU (I forgot the name, sorry, but is not the VTG).
      02-09-2024, 08:32 AM   #4
Estvander
Estvander's Avatar
Drives: 2017 bmw 330i gt X-Drive
Merlino, could you explain this better please. I'm getting the same error and the car seems mechanical great. I'm thinking its a electrical issue. I'm getting a flexray issue as well.
So your saying to code thr DSC and something else?
Thanks.
      02-09-2024, 08:34 AM   #5
Merlino31
Merlino31's Avatar
Italy
The solution was replace the transfer case
f30post
