11-24-2008, 02:31 PM | #1 |
86
Rep 847
Z4 carputer
I was wondering, has anyone here installed a normal computer in a Zed? The navigation screen looks very decent for a computer and given the far out-dated functionality of the nav system and otherwise lack of robust entertainment, a computer can be a sweet addition!
11-24-2008, 09:23 PM | #2 |
32
Rep 746
Drives: 2009 Honda Civic Si
How would one go about such a mod and how practical would its uses be while moving down the road?
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD 09' 2.0 Polished Metal Metallic Honda Civic Si - Current |
11-25-2008, 01:57 AM | #3 |
88
Rep 1,090
It would be good if we could tap into the screen.
You could use it play dvds, hook up parking cameras, display engine read out info. I dont know if it has any video in connections that we can plug a carputer/other devices into.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
11-25-2008, 06:53 AM | #4 |
218
Rep 4,726
You can with an auxiliary module, and somewhat without one as well as far as I know.
11-25-2008, 08:44 AM | #5 |
44
Rep 205
There are ways to tap into the factory screen. I did alot of research on this last year, but gave up cause I could not find a screen. There is a lot of cool stuff you can do with a carputer especially in a BMW with ibus, as everything is run of codes (IIRC it is HEX or something). If you want to do this, do alot of research. www.mp3car.com is a good way to find information on this. You can run GPS, MP3, movies, Bluetooth phone all off the carputer.
This guy took a Z4 Screen and a carputer and put it in his 540i. http://web.mac.com/jlitko/iWeb/BMW%2...5E0706921.html http://www.mp3car.com/vbulletin/work...-part-2-a.html http://web.mac.com/jlitko/iWeb/BMW%2...0Part%202.html http://www.bimmerboard.com/forums/posts/142176
11-25-2008, 02:33 PM | #7 | |
86
Rep 847
Basically what J Factor and Nate96 said: you will have access to a whole array of entertainment options, internet, a good GPS, etc. I retrofitted the factory nav a few months ago and the lack of fuctionality is just pathetic! A sub-$100 GPS does much more than what this system does. As for HOW, I was thinking either through a video module (i.e. you add a video module to the nav system and connect the computer via A/V input) or even the more elaborate way of tapping directly into the IBUS as Nate96 mentioned. There's this guy who also makes an IBUS to USB module: http://www.reslers.de/IBUS/ and here's an example of what can be accomplished with it: http://web.comhem.se/bengt-olof.swing/CarPCProject.htm |
11-25-2008, 02:55 PM | #8 |
z4um Hooligan
140
Rep 586
Or you could go this route...
What you would need is an Mini-ITX Computer. The whole computer is siting to the right of the CD case. More info here. http://damnsmalllinux.org/store/Mini..._Small_Machine You can buy a starter bundle here. http://www.mini-itx.com/store/?c=44
Charles
flickr |
11-25-2008, 03:03 PM | #9 |
44
Rep 205
You do not need to go with after market. If you search around (I think on the link I provided) is a way to connect to the factory. But with an after market you would get a better screen, touch screen if you wanted. The possibilities are endless, depending on how inclined you are.
On ebay you can find some carputers that just require installation.
