12-26-2021, 08:50 AM | #1 |
50
Rep 218
Why AFR is jump when shift?
https://www.bootmod3.net/log?id=61c5...90c63ffe52042d
log is here,I am very curious why.. I think when AFR jumps high, there is no power,I even feel this.I lost 0.05-0.1s while shfiting, I mean shifting gears are not fast enough Last edited by MaverickCruise; 12-26-2021 at 10:36 AM.. |
01-03-2022, 11:49 PM | #2 | |
484
Rep 1,066
Edit: you have timing corrections all over the place. What gas/octane/area + what tune are you running?
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
01-04-2022, 04:52 AM | #3 | |
50
Rep 218
The AFR change may be no fuel injection that time, but there seems to be no reason for the gear shift to be slower. Runing 98RON,big turbo, BM3 customer tuning, 23psi peak boost. How much time does your car takes 0-100KM? thanks |
01-04-2022, 09:30 AM | #4 | ||
484
Rep 1,066
01-04-2022, 11:26 AM | #5 | |
50
Rep 218
Why no try? MT will little slower then AT, but at least we should know the general data. I think 0-100 acceleration performance is more useful for daily. Higher speeds are not used much on my side. I want more horsepower and also want a faster 0-100 acceleration My 328 when used stock turbo, the fastest reached 5.01s for 0-100km.But now everything slowed down, one of the reason is tire, it was 285, now it's 255, I have seen the data tire affected 0.2-0.3 seconds for 0-60km.Then there's the slower shift from 2 to 3 gear, where I lost 0.1-0.2s, compared with the previous data. Even after subtracting these factors, I still don't feel fast then before. This has always bothered me. |
01-04-2022, 12:26 PM | #6 | ||
484
Rep 1,066
Best I have logged is 5.51. This was taken 4-17-21. Maybe I'll do a log or two later today for funs.
01-04-2022, 01:13 PM | #7 | |
50
Rep 218
5.29 and 5.01 are same hardware configuration, I tuned with JB4 my self at the time, and did it in May 2017, 5.83 was last month. |
01-04-2022, 01:31 PM | #8 |
484
Rep 1,066
I'm hoping to be in the 4s now at least. FBO + stage 2 turbo + new mounts (motor and trans). Not sure if that's cheating, but with this winter blend gas (made me pull out a lot of timing + only at 19psi instead of 24) I should be around 330-340whp instead of 360-370 on 93.
01-04-2022, 01:47 PM | #10 |
484
Rep 1,066
30psi ? That car/turbo is this ? My understanding is the n20/n26 is limited due to the turbo exhaust turbine and back pressure.
01-04-2022, 02:04 PM | #11 | |
50
Rep 218
01-04-2022, 02:16 PM | #12 | |
50
Rep 218
We follow his record of 25 psi, which is close to M2 N55 with the help of methanol kit. Maybe that means 25 psi + methanol to get closer to 370 HP? |
01-04-2022, 02:27 PM | #13 | ||
484
Rep 1,066
The only way to solve this is to get a td05 exhaust turbine and have it machined to fit a td04 and weld it to the stock manifold. Not sure of any that can do so (currently digging just because) but if we can find one, in theory, make more power with back pressure not being the limitation anymore for hybrid/stage 2 turbos while keeping the same spool up. The MHI turbo for example is rated to be balanced up to 32psi. If that's the case, from 27-28 to 31-32 psi is leaving 30-40hp on the table without the need for a custom turbo setup. It's also a possibility at lower rpm's they are aiming for 30psi and taper it down at redline. Who knows, lots of things at factor here.
01-05-2022, 05:03 AM | #14 | |
50
Rep 218
Because I usually not drive this car, my wife does. She had no idea how to check the fuel. I usually drive another car, this car equipped LSD, so I drive occasionally on weekends to enjoy drifting and track day. I have the obsession because spend much money and can't see the improvement. Even though I know that if want 0-100 faster only requires an electric car. |
