12-13-2021, 05:58 PM | #1 |
136
Rep 141
M Technology Package - What is it, and who is getting it?
I was thinking about adding this to my build if its worth it. All BMW website says is increased capacity to the drivetrain and brake cooling systems.
Anyone know the specifics? Thanks! |
12-13-2021, 07:30 PM | #3 |
97
Rep 108
Its just better tires which you can get later, a cooling fan and oil cooler you probably will never need unless you hard core track it.
12-13-2021, 07:52 PM | #4 |
157
Rep 196
If you are still keen on getting the 245 Front and 255 Rear, it looks like you could still option them on the 792 wheel with performance non RFT for no charge (great deal I think) and potentially save $2400 unless you need the 893M wheel and the additional cooling like mentioned above by other members
12-13-2021, 09:18 PM | #5 |
529
Rep 653
Drives: 2022 G20 M340i
Garage List 2021 BMW X5 [0.00]
1991 Ford Mustang GT [0.00] 1993 Ford SVT Light ... [0.00] 2020 Harley-Davidso ... [0.00] 2013 Porsche Boxster [0.00] 2018 BMW 340i M-Spo ... [10.00] |
Dont forget the fender lips too. LOL
Chuck
2022 G20 M340i PB/Oyster Last- 2018 F30 340i 6MT ZHP AW/CRed |
12-14-2021, 07:12 AM | #7 |
72
Rep 110
12-14-2021, 06:15 PM | #9 |
11
Rep 15
Fender lips
12-14-2021, 06:17 PM | #10 |
11
Rep 15
wheel opening lips
12-14-2021, 09:48 PM | #11 |
157
Rep 196
Lol good point. I’m curious if they’ll put the fender lips on the 792 with performance non RFT’s also since they get the same wheel/tire size as 893M.
I decided to order today with the 797 so I will know sometime in March hopefully when my car comes in. |
12-15-2021, 01:50 AM | #12 |
2623
Rep 1,477
Drives: BMW M2
There's some confusion, the extended lips only come with the largest wheels (893m with 245/255 tyres), it's purely a matter of aesthetics to accommodate wider wheels (8.5"/9.5") with deeper offsets and prevent the wheels from coming out of the wheel arches.
With all other wheels there will be no extra lips since they are all 8"/8.5" with 225/255 tyres. |
12-15-2021, 05:58 AM | #13 | |
157
Rep 196
12-15-2021, 06:08 AM | #14 | |
2623
Rep 1,477
Drives: BMW M2
Same rims already seen on the M340. https://www.bimmerworld.com/BMW-5x11...118089894.html https://www.bimmerworld.com/BMW-5x11...118089895.html |
12-15-2021, 06:25 AM | #15 | |
157
Rep 196
The one thing I will say though is the images and the video you posted show the 792M with 225 wide all season Pirellis on it. Ill try calling the BMW genius hotline and see if they can confirm the right size on the Performance non RFT's. |
12-15-2021, 10:01 AM | #17 | |
157
Rep 196
I called BMW Genius this morning again just to confirm the setup on the 792 wheel with the performance non RFT since the order guide shows 245/255 same as if you order the ZTK with the 893M wheels. The lady I spoke to confirmed that is indeed 245/255 and if you order the performance RFT's on 792M then you get 225/255. I personally am still not convinced that its true but I am going to go ahead and order it that way hoping the order guide is infact true. |
yanks1484.00 |
12-15-2021, 12:13 PM | #18 | |
25
Rep 139
Unfortunately it’s not the same on the Canadian website. You can only order the performance RFT or all season RFT with the 792 wheel. So it’s looks like the best we get in Canada in the 225/255 setup unless you order the ZTK package with the 893M wheels (in Canada called the “M Sport Pro Package”). I’m not really a fan of the 893M wheels so will probably stick with the 225/255 and the 791 or 792 wheels.
2016 Ram 1500 Sport Crew White 2014 BMW 435i XDrive M-Sport Sapphire Black 2008 BMW 135i Alpine White (sold) |
12-15-2021, 12:52 PM | #19 | |
157
Rep 196
I chose to go with Thundernight metallic and hence spec'd it with 792 since it matches with the cerium gray on the mirrors and the grill. I would've gone with 791 if I would've chosen Brooklyn Grey which was my 2nd option. |
12-15-2021, 03:54 PM | #21 | |
27
Rep 20
12-15-2021, 05:12 PM | #22 |
2623
Rep 1,477
Drives: BMW M2
Dinosoar should have the answer.
