12-13-2021, 11:35 AM | #1 |
285
Rep 1,289
exhaust valve mod
I'm sure many of you have already done this, but last night I started my car up and let it idle until the valve in the right exhaust pipe opened up. once it did, I unplugged the sensor connected to that pipe under the car, so now the valve is permanently open. this has made it sound a bit louder on startup as the value is open instead of closed. super easy mod that I would recommend for anyone wanting a bit more sound on startup.
12-13-2021, 11:47 AM | #2 | |
462
Rep 278
Drives: '22 G42 m240ix, '18 X5 35d
-Nicholas
2022 BMW m240i x-drive 2018 BMW X5 35d x-drive 2015 VW Golf 1.8t 5-speed (sold) 2004 Chevy Cavalier (hopefully crushed by now) |
12-13-2021, 12:27 PM | #3 | ||
285
Rep 1,289
Good 4 2 reasons462.00 |
12-13-2021, 04:02 PM | #4 |
529
Rep 653
Drives: 2022 G20 M340i
Garage List 2021 BMW X5 [0.00]
1991 Ford Mustang GT [0.00] 1993 Ford SVT Light ... [0.00] 2020 Harley-Davidso ... [0.00] 2013 Porsche Boxster [0.00] 2018 BMW 340i M-Spo ... [10.00] |
Interesting. So is this basically like having the "sport mode" exhaust level but in every setting (comfort, etc)?
Chuck
2022 G20 M340i PB/Oyster Last- 2018 F30 340i 6MT ZHP AW/CRed |
12-13-2021, 05:50 PM | #5 |
285
Rep 1,289
I think it just makes it louder on startup. as for the sound of the exhaust in the different driving modes I think that is mainly controlled by the active sound. however I'm sure someone else on this forum may know more about this than I do.
12-13-2021, 08:31 PM | #6 |
11
Rep 15
I was under the impression that the louder exhaust on cold starts on BMW turbo engines was the waste-gate bypassing the turbo to lite off the catalytic converter in order to reduce cold start emissions.
12-13-2021, 09:16 PM | #7 |
529
Rep 653
So the OEM exhaust isn't valved? I have the MPPSK on my 340 and its valved, guess I assumed the stock system was too on the m-sport models.
Chuck
12-13-2021, 09:56 PM | #8 | |
285
Rep 1,289
MrFoxy376.50 |
12-14-2021, 09:36 AM | #9 |
529
Rep 653
So the valve normally only opens during startup?
Chuck
12-14-2021, 11:08 AM | #10 |
484
Rep 1,188
Drives: 2008 e92 335xi
One value is open and one valve is closed during startup. Depending on your climate, this is very easy to see when the temps are cooler. You'll see water vapor only coming from one pipe.
The OP now has both valves opened, which results in both valves being opened along with a louder startup exhaust sound. A lot of people have referred to this as a golf tee mod.
mblaucoupe135284.50 cannockwolf838.50 |
12-15-2021, 01:27 PM | #11 | |
111
Rep 75
old_man_feet53.50 |
12-15-2021, 10:09 PM | #12 | ||
285
Rep 1,289
12-16-2021, 05:47 AM | #14 |
614
Rep 426
This can show you what you're looking for as well as a $500 option to make it better.
In this video it shows stock vavle on the g80 not opening all the way but once you slap the new controller on it's wide open. |
12-16-2021, 08:26 AM | #15 |
285
Rep 1,289
it's right under the car by the right exhaust tip. if you look under the car I think you will see it. I'll try to post a pic of it this weekend. super easy to unplug. I also zip tied it to the metal bracket to make sure the sensor doesn't flop around.
MrFoxy376.50 |
12-16-2021, 10:37 AM | #16 |
529
Rep 653
If the car has 2 flaps, why not unplug both?
Chuck
12-16-2021, 04:31 PM | #17 |
285
Rep 1,289
12-16-2021, 06:59 PM | #18 |
529
Rep 653
I thought someone earlier in the thread said there was 2? I don't have my car yet so I cant check.
Chuck
12-29-2021, 06:11 PM | #19 |
163
Rep 144
mblaucoupe135284.50 |
12-30-2021, 06:33 PM | #20 |
Technician
65
Rep 21
A better alternative would be to pull this fuse (F203) in the rear junction box (near the RH tail lamp under a carpet cover).
It only supplies the exhaust flap actuator. I've seen too many of those exhaust flap connectors corrode like crazy if they're exposed to water, so you'll be replacing the actuator and connector pins if you change your mind (or install the MPE later on). |
18
Vudumonkey25613.50 conradb58314.50 Ruebarb375.00 m_g42bmw42.00 burkhacs126.00 TJZ67201842.50 MrFoxy376.50 hamenfirstblood120.00 TheoK23.00 Alpine Flyer138.00 CarsAndGuitars2064.00 PP3121357.50 shonseb148.50 Dolma1.50 hyperpip21.00 Kay.Say15.00 ghostz33.00 ZeusHorkios107.50 |
12-30-2021, 06:35 PM | #21 | |
614
Rep 426
I think they have fuse switch bypass adapters so you can just add a switch and turn that fuse on off |
MrFoxy376.50 |
12-30-2021, 06:40 PM | #22 |
Technician
65
Rep 21
