12-13-2021, 08:36 AM | #1 |
289
Rep 432
BMW Patents New Rear-Wheel Steering System
Featured on BIMMERPOST.com More angle is now possible, and the future system will take up less space too. In filings uncovered by CarBuzz, the German automaker has applied for a new invention with the United States Patent and Trademark Office. Herein, the Bavarian brand claims that existing systems are too unwieldy. This is because most systems use a track rod to adjust the toe of each rear wheel, but in this space, the vehicle must also house a subframe, an axle, and additional components like a differential and side shafts. This limits angles to, "at most 5 degrees," says BMW. The solution? An additional wheel carrier on each hub, with each featuring an actuator on the lower portion that is maintained by a grooved guide. According to the documents, this could allow for as much as 10 degrees of rear-wheel angle without adding to the space constraints of the rear subassembly. If the invention makes it to production, it could have benefits across the automaker's range. On something like a BMW M4, one could dramatically reduce the virtual wheelbase, thereby vastly enhancing low-speed tight-turn handling. Naturally, high-speed stability is also improved, but we suspect that this technology will likely first do duty in a large vehicle like a new 7 Series. These luxury machines are getting larger every year, and parking them is certainly not easy. With a shortened virtual wheelbase thanks to this enhanced rear-axle steering system, monstrosities like the XM could be a little easier to live with on a daily basis.
12-13-2021, 11:18 AM | #2 |
7125
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
Now all they have to do is to fix the grille
M2CS,
The second coming of ///M! |
12-13-2021, 11:20 AM | #3 |
316
Rep 311
When adjustable grille sir?
12-13-2021, 11:21 AM | #4 |
453
Rep 1,125
Drives: 2015 BMW 435i Xdrive MSport
Wonder how much this will cost when it breaks.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
12-13-2021, 11:32 AM | #5 |
2714
Rep 2,350
I am always excited to read this kind of stuff. This should improve vehicle’s handling a lot.
It should be called 4WS - Four Wheel Steering… |
DrivenByE30595.00 |
12-13-2021, 11:35 AM | #6 |
5949
Rep 10,322
"The Prelude was the first active 4WS car sold in the U.S., but Nissan’s Japanese-market R31 Skyline came earlier, launched in late 1985."
https://www.autoweek.com/car-life/a1...g-demystified/ |
12-13-2021, 11:47 AM | #7 | |
7125
Rep 4,008
It was a fad that swept the Japanese manufacturers and faded away very quickly due to technical challenges and horrendous repair costs
M2CS,
12-13-2021, 11:53 AM | #8 |
1452
Rep 925
Cant wait for $900 alignments
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
12-13-2021, 12:06 PM | #9 |
3689
Rep 2,956
The 3000GT VR4/Stealth and 300ZX had it in the early 90's as that's kind of where it peaked.
MadBimmeRad7124.50 |
12-13-2021, 12:07 PM | #10 |
3202
Rep 1,669
Mitsubishi 3000GT had this too.
edit - damn, beat me to it while I was typing.
Ego is the anesthesia that deadens the pain of stupidity.
The single biggest problem in communication is the illusion that it has taken place. Wheel horsepower is just crank horsepower after taxes. IG: EmFore_650 |
12-13-2021, 12:24 PM | #11 |
4844
Rep 2,744
I can understand the theoretical improvements for parking lot maneuvers, but would rotating the rear wheels more than 5 degrees really be useful (safe) at speed?
12-13-2021, 12:39 PM | #12 | |
363
Rep 319
Yeah, they have sensors and cameras ... parking is pretty damn easy. It is almost like consumers are buying vehicles that are larger than they can actually operate. -Michael |
DrivenByE30595.00 |
12-13-2021, 12:57 PM | #13 |
Ring Leader of G8X Haters
25176
Rep 8,768
This will easily be a welcome addition to vehicles like the 7-Series and would make the car better to drive and much easier to maneuver. I've tested out MB's 10-Degree RWS on the new S-Class and EQS and it makes maneuvering such a large car much easier, and it decreases the turning circle to as little as the sub-compact A-Class.
12-13-2021, 01:05 PM | #14 | |
5949
Rep 10,322
DrivenByE30595.00 |
12-13-2021, 01:18 PM | #15 |
3437
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
RWS was one of the many changes to the Porsche 991 chassis that made it leaps and bounds better than 997. But the reason for adding it was performance. Not parking.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
DrivenByE30595.00 |
12-14-2021, 10:50 AM | #17 |
3689
Rep 2,956
Nobody said it had this exact method of 4WS. It was simply noted that rear wheel steering was used in several cars in the late 80's and early 90's. HICAS still turned the wheels.
12-14-2021, 12:08 PM | #18 |
1231
Rep 845
The hell are you talking about? Guessing you think the figures are side view when they are in fact top view. No camber adjustment, only steering adjustment as has been stated.
Instagram: @Project_F87
12-14-2021, 12:13 PM | #19 | |
61
Rep 56
