12-06-2021, 03:57 AM | #1 |
Rep 23
Blower problem hot and cold
My f32 has just developed a blower problem. I can’t change from hot to cold or vice versa.
if I’m in the car and it’s set to 16c when I start it I cannot get it heat. But if I start the car with the heat setting on 28c I then can’t get it to blow cold. ive trawled the internet to find the fault and it seems to point towards the blend door actuator? as it will intermittently blow hot or cold but will not allow me to alter the temp. has anyone had this problem? Does anyone know where I will find the location of this actuator? |
12-10-2021, 01:25 PM | #2 |
Rep 23
Update, windscreen defrost blows hot and cold and the control works changing from heat to cold.
Front blowers won’t change between hot and cold Had the codes read and comes out with this. E70C1E - motor defrosting or central drive does not respond E70C20 - motor mixed air or mixed air left not responding E70C21 - right mixed air motor does not respond E70C23 - motor ventilation left footwell does not respond E70C24 - motor ventilation right footwell does not respond E70C27 - motor stratification front left does not respond E70C28 - motor stratification front right does not respond E70C29 - motor recirculation does not respond E70C2C - motor recirculation does not respond E70C31 - PTC module does not respond Anyone have any ideas on this please? |
06-20-2022, 03:28 PM | #4 | |
Rep 2
Have you figure it out ? I am having same problem aswell f30 🥺 Can any one help please |
06-20-2022, 03:40 PM | #5 |
Rep 23
06-21-2022, 01:34 PM | #8 |
Rep 2
