BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      11-22-2008, 12:55 AM   #1
clubspec330i
71
Drives: MG F39, CB F86, MB 911T
Would a 275/35-18 works all around?
I went to AAA Speedway today. First time being on that track. What a great experience indeed!
A gentleman next to me went out for the first time in his mint E39 M5..He was running 275/35-18 RA1 all around. From what he told me, his wheels are 18x9.5 all around. Now, if he can use 275 on his M5, than 275 would certainly works on the M3 but would it be too much for the front??
What do you guy think? Why did you go with 265 instead of 275?
      11-25-2008, 04:54 PM   #2
masmole
266
Drives: blue, gray, brown cars
Shouldn't be a problem. 275/35/18 is the size Turner motorsports runs on all fours at the track on their E90 M3. They use 18x10 Forgeline wheels but an 18x9.5 width should work just fine too with that size tire. It makes for an ideal square set if you want to go that route.
I'm planning on going with four 18x9.5 Volk TE37s for a square set for the track. The great thing about that size is that there are many tire options. 275/35/18 gives you the choice of BFG-R1, Hoosiers, Nitto NT01, Toyo R888 or RA1, to name a few good ones.
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7
      03-18-2009, 10:28 AM   #3
syncros
12
Drives: 2008 M3 Coupe
Hello.
I'm looking at buying a set of 4 wheels in 18X9.5 with 275/35/18 all around on my E92. Do you if the setup from Turner was with stock suspension and stock fenders?
Thanks for your help, Vincent
      03-19-2009, 11:46 AM   #4
masmole
266
Originally Posted by syncros View Post
Hello.
Turner's E90 definitely has aftermarket suspension. It's pretty low too, although I'm not sure what springs or coilovers they're using. The E9x M3's have obscenely large fenders and as long as you don't go nuts with too aggressive of an offset or width up front, you shouldn't have any problems even with a lowered suspension. I'd be more worried about suspension clearance if going with anything larger than a 9.5" width rim up front. Turner and a few others use a 10" rim up front and seem to have no issues.
I have a square set of 275/35 NT01s mounted on LTW5 18x9.5 ET35 with 12mm spacers all around effectively making them +23 offset wheels, and with Eibach springs installed, I have no issues although I haven't taken it to the track yet.
      03-19-2009, 07:11 PM   #5
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
275 all around will work - I run 265 all the way around. probably 265 front and 275 rear would be more ideal. but then you cant rotate front to back.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      03-19-2009, 07:24 PM   #6
syncros
12
I'm looking for a square setup. If it can fit in front with 18x9.5 wheels and need spacer that is fine. How tricky is it to use spacers? I've never had a car with spacers before? Are they tough to find?
Thanks again guys, Vincent
      03-20-2009, 02:18 PM   #7
Dascamel
Dascamel's Avatar
48
Drives: 2008 e92 M3, 2010 e91 328i
+1
Also looking for info on the this, would spacers be needed if running 18x9.5 on all fours with 275 tires?
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      03-20-2009, 03:53 PM   #8
8INTO3=M
Drives: M3 Coupe -- Interlagos Blue
Cool Spacers needed for clearance or for looks?
I'm thinking about this too. Wondering if you need the spacers for clearance or are they really for the better looks?
I'm wonding if I can stuff an 18" x 10" in front with 25 offset? Any ideas?
      03-20-2009, 04:57 PM   #9
sayemthree
sayemthree's Avatar
597
spacers are no big deal. if you want square with the same wheel sizes and offsets you need about a 10 mm spacer in the rear depending on the offsets. I end up with no spacer in the front and 5 mm in the rear. I really should go to 10mm tho in the rear.
see link
http://www.m3post.com/forums/showthr...ght=sayemthree
      03-26-2009, 08:30 AM   #10
bogdan
bogdan's Avatar
37
Drives: 911
I'm running 265/40/18 PS2 up front and am getting some rubbing on the fenders. This is with the stock rears. Stock rideheight. No spacers.
I can't remember the offset of the stock rears. Anyone know?
OP-275/35's should be ok providing the right offset.
gone, not forgotten: Viper | Z06 | E90 M3 | E92 335i
Originally Posted by Mjolnir View Post
My dog swallowed my FOB. Luckily it was Comfort Access so I could still drive the car. Of course I had to take him with me everywhere and every time he rolled over the windows went down.
m3post
