11-29-2021, 08:21 PM | #1 |
84
Rep 161
Engine cutoff below redline
Stock m2c 16k miles. Wanted to rev out engine a bit after endless stop and go traffic
Initially reached redline once in 2nd, but then engine would bog down near 6-6.5k several times afterwards with what felt like fuel cutoff. Could not reach redline again rest of drive. No cel or other warnings. Never experienced same in S2000 which happily hit redline repeatedly all day long. Last edited by Brokenbones; 11-29-2021 at 10:35 PM.. |
11-29-2021, 11:09 PM | #2 |
26
Rep 78
Drives: 2020 BSM M2C
it's the de-tuning of the s55. falls flat after 5300ish rpm.. get a tune
11-30-2021, 07:25 PM | #3 | |
1424
Rep 1,821
Something is not right. It should still be checked with a diag computer for stored codes. Lack of CEL doesn't mean there are no codes.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
11-30-2021, 08:17 PM | #4 |
4041
Rep 3,548
Drives: 328d Wagon, M2 Comp, i4 eD35
There's some protection mechanism that limits your redline pulls in lower gears. I'm not sure if it's a DCT thing, or diff thing, but my DCT car will only let me rev out first and second gears a few times in a row before encountering the cutoff you mentioned. In third and above gears I can do constant redline, then coast down, then redline again, then coast down, ect over and over again.
I found this out while breaking in my engine where I'd do gradual pulls to redline, then coast down, and repeat.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
Enabled1424.00 |
11-30-2021, 08:46 PM | #5 |
3280
Rep 3,257
I can’t speak to the DCT, but if you can’t rev it out in a manual then something is definitely wrong. If you have the DCT, can you reach redline in “manual” mode?
11-30-2021, 08:51 PM | #6 | |
1424
Rep 1,821
12-01-2021, 12:32 AM | #8 |
20
Rep 23
Drives: 21 LBB M2C 6MT
I've had this exact thing happen to me twice very early on in ownership at around 1500 miles. car refused to go past ~6k rpm in 2nd and felt.like it hit a rev limiter from the sound. oil and the car were fully warmed up. I tried it again after letting off the gas and it did it again, after which I decided not to push my luck and shifted into 3rd.
I've never had it happen since then though |
12-01-2021, 05:32 PM | #9 | |
84
Rep 161
Thanks for reply guys |
