E91 N52 Plugged Cats??
11-29-2021, 06:41 PM | #1 |
13
Rep 92
Moving this from main forum....
So my son's E91 LCI w/N52 developed very rough idle. I had the BMW Scan Tools and noticed 02 post cat readings were fluctuating to 0 at times. So I replaced the post cat o2 sensors. Soon after this the car started to run rougher and developed an exhaust leak right at the post-cat flange. This area was super rusty and I'm not surprised that I may have created the leak while replacing the 02 sensors. When I mean rough, I mean it sounds like it is running on 4/5 cylinders. Before heading to the muffler shop I did order new spark plugs and coils...sort of maintenance and possible fix, but not installed yet. Previous owner addressed the vanos motor, new valve cover. Can just hit 80k. The exhaust shop just called and confirmed the exhaust leak, but also found that cats were plugged up during flow test. Cats had 3% back pressure vs. 0%-1% target. Not sure how they run this (first for me) but they say the cats are "plugged up". So the exhaust leak turned from $200 weld job to $3,000 cat replacement. I'm just having them cut and weld in new flanges at the moment, but I do need to address the "plugged" cats. Any suggestions? I'm thinking either; 1) eBay headers and 200 Cell magna flow cats... still want 02's working, emissions, etc.. 2) Used N52 exhaust w/cats from eBay/Forum classifieds also....We did use seafoam cleaner in the tank months ago, could this have plugged up the cats?? |
11-30-2021, 05:54 PM | #2 | |
996
Rep 2,287
Miss fires are ignition or fuel related. Have you read the engine codes using a BMW specific code reader? |
11-30-2021, 07:47 PM | #3 |
315
Rep 474
Drives: 2009 128i 6MT
If they really are clogged you might try cutting out the secondary cats to see if that makes a difference. Would be tough to tell which specific cat is clogged but worst case with the secondary delete would be you pay to have them put back in if you don't like the sound or pick up a smell.
