11-08-2021, 01:36 AM | #1 |
Rep 34
M40i squared setup question, cant find a definite answer.
I'm sure this have been answered somewhere, but just want to make super sure before ordering the tires.
Can I order 4x 245/45 R20 winter tires instead of staggered ones? Will 245/45 fit on the back rims that have 275/40 OEMs? |
11-08-2021, 04:02 AM | #3 |
Rep 34
Rik the car will come with summer tires, I want to buy a square winter set, same size as the front for all four wheels (245/45 r20). The rear rims are wider (9.5in) so I'm not sure if the front tire size will fit or not.
11-08-2021, 05:07 AM | #4 |
A family of bimmers
2757
Rep 7,743
They will fit but because of the stretch they will be shorter in diameter potentially causing issues with the AWD system.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
11-08-2021, 12:13 PM | #5 |
228
Rep 288
Drives: '22 X4 M40i / '24 X5 M60i
Look what is BMW approved cold weather winter set: 20" Double Spoke 699M, Orbit Grey P/N 36110003064
Pirelli® Scorpion Winter 245/45R20 103V XL It is a square setup. I do not think there will be any issues with AWD system. |
11-08-2021, 12:19 PM | #6 | |
Rep 34
Staggered set is just $75 more so pretty much negligible, might go for it after all just for peace of mind. |
11-08-2021, 12:27 PM | #7 | |
513
Rep 914
You would need 36112472751 on the rears, i.e. 275/40 R20 106V XL |
11-08-2021, 12:50 PM | #8 |
736
Rep 3,274
No, the recommended range for 20 x 9.5 inch wheels is such that 245's are too narrow and you will have to stretch them to fit. They will probably go on, but will have noticeable stretch to the sidewalls, the handling and grip will be compromised. Just spend the $75.
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
11-08-2021, 01:32 PM | #9 | |
6659
Rep 15,858
If you are getting new rims and tires then you have a choice of going square. |
11-08-2021, 03:02 PM | #10 | |
228
Rep 288
This is square winter setup BMW offers in Canada for G01 (incl. M40i) winter set under P/N 36110003064: Last edited by Treeboy; 11-08-2021 at 03:24 PM.. |
11-08-2021, 07:37 PM | #11 | |
89
Rep 123
OP has a staggered setup with: --Front: 20x8" ET27 with 245/45-20 --Rear : 20x9.5" ET43 with 275/40-20 Agree with others, not advised due to the fact the tire will be stretched. Some shops may decline to mount the 245/45-20 on the rears because many tire manufacturers specify 9" as the maximum wheel width for this size. |
Treeboy228.00 |
11-08-2021, 09:10 PM | #12 | |
A family of bimmers
2757
Rep 7,743
11-09-2021, 03:35 AM | #13 | |
6659
Rep 15,858
Simply put, the rear rims are too wide for what the OP would like to do. |
11-09-2021, 07:12 AM | #14 | ||
A family of bimmers
2757
Rep 7,743
11-09-2021, 08:21 AM | #15 | |
6659
Rep 15,858
OP really needs a couple of extra 'front' sized rims, to go square, even if changing tires seasonally. Two could stay mounted, just swap the other two. |
11-09-2021, 09:18 AM | #16 | |
513
Rep 914
11-09-2021, 09:36 AM | #17 |
6659
Rep 15,858
11-09-2021, 05:25 PM | #18 |
537
Rep 745
You can usually get both square and staggered setups here in Europe on either the 695 or 699 rim directly from BMW. But at the moment the square setups are out of stock.
Mounting a 245 tire on the 9,5 rim is no option to considder. But related to the initial question of this thread if the goal is to keep the budget low I would get some decent aftermarket rims and have a set of wintertires instead of swapping tires on one set of rims. Or if you want to stay with OEM rims instead of paying a fortune for two spare 699 8x20 rims I would recommend to have a 19" set for the winter. Thats what I did and quite happy with it. Also the 19" are not so easyly damaged in potholes or curbs hidden in the snow |
11-09-2021, 11:35 PM | #19 |
Rep 34
Thanks for all the replies.
I found a good deal on Bridgestone Blizzak LM005 in 275/40 20 size, so I just went with OEM sizes: 2x 245/45 for the front and 2x 275/40 for the rear, all made in 2021. Turned out to be like $25 more over 4x 245/45. |
