Intercooling cooling
10-23-2021, 06:27 PM | #1 |
Rep 16
Looked on here for some thing on this but did not find anything or if its need with an large intercooler upgrade already as i am new to bwm. Since i live in the hot part of ca 100 plus almost every day in the summer i came up with a water wetter for my wifes super charger air to water heat exchanger that has worked well for many years and plan to make one for the bmw. I already have an large intercooler that came on the car but since it gets hot here i am making one for the bmw. Its simple and cheap to make and drops the intake temp fast. I use about 20' of 1/4" water soaker hose pull tied to the intercooler bars with an 12v 3gpm pump set at 20psi soaking an water / ammonia mix from the wiper tank all controlled with an simple on off toggle to an adj hob switch set at around 18psi.
10-24-2021, 03:02 PM | #2 | |
973
Rep 3,219
Methanol injection if you absolutely must have extra cooling. Last edited by Saif2018; 10-25-2021 at 04:31 AM.. |
10-25-2021, 12:01 AM | #3 |
300
Rep 884
Just get a simple AEM meth kit with charge pipe nozzle cooling and you're good to go. It's like $450 for the kit. Not only will you get cooler intake temps in the summer, but you'll get a decent bump in octane depending on what mix you use.
2013 335is - sold
2011 335d |
10-25-2021, 09:56 AM | #4 |
BimmerPost Supporting Vendor
24331
Rep 191,093
if you are running stage 1 or stock, get a 5" intercooler
If you are pushing more power I recommend 7"+ MAD, BMS and ARM are probably the best value.
10-25-2021, 12:24 PM | #5 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
1) Get a 7.5'' IC 3'' in and out from a reputable vendor. This is basically the largest IC you can fit with a good fin pack.
2) Install a meth kit as said above. Cheap and much better for cooling and you will get increased AKI because of the water/meth 3) IC sprayers are ok but not really worth it. You will be filling up your WW tank a lot to boot. 4) If you have E85 access run E85 vs. pump gas because of AKI index.
10-25-2021, 02:34 PM | #6 |
Rep 16
Thanks every one. My car came with a intercooler that's about 8" tall but have no idea of brand. I run it on an e65 mix as i do not think my fuel system will not support pure e85. It also added 65lb port injectors. As for intake water/mech spray kit i am not that big of fan. On my super charged cars i use extra injectors and spray methanol into the super charger intake that's good for 1.5psi and after the intercooler for cooling, Works very well on long wot 1/4 to 1/2 mile pulls. My drip/ soaker system is mainly good for very hot days and normal driving with short burst of high boost. It uses about 2gallon a minute so it last fairly long and extremely cheap to easy to refill.
10-27-2021, 09:12 AM | #7 | |
24331
Rep 191,093
10-27-2021, 09:57 AM | #8 | |
700
Rep 1,229
Torgus3781.50 |
10-27-2021, 11:40 AM | #9 |
Slow.
3782
Rep 7,151
From my understanding:
- you spray it with fluid that is well below ambient temperature to increase cooling - you spray it with fluid that is ambient temperature to prevent heatsoak and hope there is some evaporative cooling going on. The benefits of preventing heatsoak can easily be remedied with a beefier intercooler core, so using it for that reason is sort of.. meh. Using it with below ambient fluid makes sense, but you'd need to cool down the fluid a lot, and again... it's not lossless so you'd constantly have to refill it and unless you run an AC loop how do you cool it? The only problem with the refrigerant set-up is that you would have drag from the AC compressor all the time. Throw ice in a box in your trunk every time you go for a drive? If you are going through the hassle of running tubing and pumps to support such a thing why not just install a meth kit and have significantly better gains? but you do you. edit: You don't even have to inject meth. You can use straight water, windshield washer fluid, etc. If meth 'scares or bothers you' there are still better gains by injecting into the intact track vs. spraying the IC.
10-28-2021, 10:14 AM | #10 | |
Rep 16
10-29-2021, 12:02 AM | #11 | |
700
Rep 1,229
10-29-2021, 09:34 AM | #12 |
Rep 16
No the bmw does not have an soaker yet. That was why i asked on here as the bmw has an air to air intercooler thats not as efficient IMO as an air to water intercooler on the amg. I recently made up an test soaker system for an air to air intercooler but to date have not had the time to do any testing. You are an engineer so if its over 100 deg and you soak 80 deg or less water on that heat exchanger / intercooler what would happen ???
10-29-2021, 09:39 AM | #13 | |
Slow.
3782
Rep 7,151
From my understanding: - you spray it with fluid that is well below ambient temperature to increase cooling - you spray it with fluid that is ambient temperature to prevent heatsoak and hope there is some evaporative cooling going on. If you are going to spray water spray it into your CP. You have to run the same pump, tubing etc. At least CP injection has significant benefits.
10-29-2021, 09:53 AM | #14 |
Rep 16
My intercooler core is about 20" L x 8" tall on its face and at the bottom 5" wide but it looks to be only about 2" wide on top (Hard to see or measure) looks like a step. Is that a decant sized a/a intercooler for my bmw ???
10-29-2021, 09:58 AM | #15 | |
24331
Rep 191,093
5" intercoolers are suitable for lightly tuned cars. I recommend 7" on stage 2+ applications, but daily drivers can get away with using the 5" as it's still a significant upgrade overstock. But to answer your question, i would need to know which intercooler you have on the car, your mods and/ or a datalog as not all 5" intercoolers are equal
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 10-29-2021 at 10:21 AM.. |
10-29-2021, 09:59 AM | #16 | |
Slow.
3782
Rep 7,151
In my opinion people should just spend the money once and get the largest IC they can fit. It will work from stock twins to making 1k whp. Cry once buy once and you never have to think about it again. Anytime you have to buy the same aftermarket part twice to upgrade, even after used resale factored in, you are significantly upside down on $$$ spent and labor(yours or what you pay a shop). Once you have the largest IC you can fit spray in your CP. The AIT reductions are great. Add some meth or WW fluid and you gain a nice amount of AKI. This is ESPECIALLY helpful in warm environments.
stewbets448.50 |
10-29-2021, 10:55 AM | #17 | |
Rep 16
10-29-2021, 02:43 PM | #18 | |
Rep 16
10-29-2021, 05:22 PM | #19 |
Slow.
3782
Rep 7,151
I would not inject meth at the turbo snout. You certainly can. But there is plenty of charge pipe from the ic exit to the tb. If you want multiple nozzles I would do two facing each other or slightly offset at the charge pipe as far away from the tb as possible.
If you want more I would do a 3rd meth bung on the intercooler exit where you can trill and tap you can even do a 4th but at that point why not run port meth if you need that much meth for fueling. I was under the understanding thronged the meth travels the more it mixes evenly in the air. Perhaps this is wrong? But no reason to run both port meth and e85. Overkill when one or two in the cp will do just fine on top of e85. If you are running full e85 2 in the cp should be more than enough to cool the AITs and add some aki on top of the e85. I guess if you do all of this spraying the ic would be icing on top and helpful in high heat environment on along pull like a 1/2 mile event. Many tracks do not allow you to spray an ic with liquid but if you don't drag race or track who cares. Please post your final design, be fun to see what it all looks like. Will you use a hobbs switch to trigger the spray? Like at 15 psi for example. |
10-30-2021, 09:56 AM | #20 | |
Rep 16
Here are a few pics of an test soaker setting on a friends intercooler. Water is only at 14psi. Soaker hose manufactor claimes the hose can safely take 50psi but i use 20psi in the past and 20 foot flowed 2gpm |
