10-22-2021, 12:44 PM | #1 |
Rep 93
Servicing
Anyone have details of the service schedule on the ix3 and how much servicing is in the UK?
It’s my first electric car so I’m clueless! It’s been a while since I owned a BMW let alone an electric car ha ha
My BMW's - past and present
2002 E46 318i SE 2009 E92 330i MSport Coupe 2021 G08 IX3 [ordered] |
10-22-2021, 02:28 PM | #3 |
23
Rep 67
If it's like the i3 it'll be brake pads/fluid, air con/filters and at year 4 they will try to get the air con regassed or whatever it's called. I expect as their servicing profits fall as more and more people move to electric the stealers will find more and more things that need doing….
10-22-2021, 04:33 PM | #4 | |
6659
Rep 15,858
10-23-2021, 05:11 AM | #5 | |
37
Rep 164
They also wash and vac the car. It is interesting how times have changed. My first i3 servicing just over 4 years ago was a 2 day affair. The car had to be fully charged and left connected to BMW’s servers for a system fault check and firmware updates. |
10-23-2021, 10:35 AM | #7 | |
37
Rep 164
10-23-2021, 11:13 AM | #8 |
6659
Rep 15,858
Would definitely be my issue up here and is one key area where I'm put off EV. I'd be adapting to one pedal driving for efficiency.
Premature brake replacement is the weak point in my driving anyway, corrosion ruins discs way ahead of pad wear. Last front set came off with 9mm of pad remaining. |
10-23-2021, 01:14 PM | #9 |
102
Rep 601
The 225xe I've got gets brake glaze over pretty easily, but the car does 'tap' the brakes to clear the pads and disks of buildup at low speeds, you can feel it slightly tapping them every now and again when just rolling at 10mph or so. Not enough to slow you down, but if you have the windows open you can hear them doing it, and if you left foot brake so have foot resting on the pedal for any reason you can sort of feel it pulse through the pedal.
10-24-2021, 01:50 AM | #10 |
47
Rep 126
Here in Holland first service is after 2 yrs from first road access. Will refresh brake fluid and check air-con.
Wear on break pads will be minimal as braking is done regaining electrical power. Best way here is drive in B-mode. Will save even more in money then |
DaveCV37.00 |
10-25-2021, 02:15 AM | #12 | |
37
Rep 164
A lot of the other components are subject to condition based servicing; eg; brake pads. |
10-25-2021, 03:46 AM | #13 |
12
Rep 81
