Wheel spacers = need geometry check ?
11-16-2008, 01:28 PM | #1 |
Lamininist
82
Rep 1,030
When adding wheel spacers, is it necessary to get the geometry set up again ?
It is altering the wheel base at the end of the day and hence the presentation of tyre to road ? Yves |
11-17-2008, 11:39 AM | #2 |
732
Rep 3,735
Spacers don't alter the wheelbase at all, it alters track width.
If you widen out the rear considerably, you have a better chance of understeering, but at the same time, you have a more stable rear end.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
11-18-2008, 02:55 PM | #4 |
Lamininist
82
Rep 1,030
11-18-2008, 04:40 PM | #5 | |
732
Rep 3,735
you do not need an alignment from installing spacers. It has no affect on it at all. Spacers widen out wheel track (essentially making the car wider). It does not alter wheel base either as you mentioned in your first post. A wider stance (if front and back is done in correct propertions) will actually improve your handling and traction because you are spreading out the force applied to each corner. Think of it like this... you are standing on a sheet of glass which has no support except around its edges. The closer you bring your mass to the center of that sheet of glass, the greater the flex and the greater the chance of breaking that glass. Now, lets say you start to spread yourself out over the glass, you are distributing your mass away from the center. Does that make sense? When you widen track width, you are essentially allowing the car to spread its mass out. Many automotive instruments can back this up (ie. tire pyrometer).
11-22-2008, 10:35 PM | #6 |
46
Rep 997
How big is your front spacer did you go? Is you car with the spacer now do not track as straight as without spacer?
FS: OEM M Sport Rear Sway Bar
http://www.e90post.com/forums/showthread.php?t=246838 |
11-22-2008, 11:19 PM | #7 | |
117
Rep 1,764
FWIW, suspension designer will sacrifice camber curves and other variable for proper KPI offset. In just happens no one really cares. Orb |
11-22-2008, 11:24 PM | #8 |
46
Rep 502
I had to take my H&R 5mm spacers off the front. Since they don't have the larger defined Hubcentric lip of the rear 10mm spacers that are on the rear of my e93, they wouldn't stay perfectly centered and the front wheels would vibrate & the car seemed to track strangely...
"WorldsQuickest 335i E93"
SMART-Top /One-Off Opaque Vinyl EYELIDS / 30% TINT / A.C.SCHNITZER Pedals / "M" Tri-Color Wheel w/Paddles / EIBACH Pro-Kit / AKEBONA F. & EBC RED-STUFF R.Dustless Pads / Drilled & Slotted ROTORS / MIRO M6 Reps / MICHELIN PS2's / U.R.Coated DP's / CYBA-QUAD Exhaust Tips / BMS-TUNED... |
11-23-2008, 09:29 AM | #9 | |
Lamininist
82
Rep 1,030
5mm spacers are now off the front and the wobbles have gone away. Leaving the 12mm hubcentric rears on as they seem OK handling wise and no vibrations. Just goes to show that BMW really do know what they are doing with the set up and if you change just one small thing, something else usually suffers. Doesnt stop us fiddling though does it ! Yves |
12-25-2009, 08:25 AM | #10 | |
40
Rep 818
