Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > What material is the intake manifold made of?
      04-28-2006, 08:57 AM   #1
ksfrogman
ksfrogman's Avatar
574
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
I was looking at the intake runners this morning. When you tap on them, they practically look like they're made out of plastic, not cast aluminum.
      05-15-2006, 07:16 PM   #2
whitecord
Drives: 500whp 318ti
because it is plastic....
      05-15-2006, 07:21 PM   #3
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
337
Drives: 2006 E90
synthetic plastic
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      05-15-2006, 07:37 PM   #4
ksfrogman
ksfrogman's Avatar
574
2006 330i  [0.00]
2006 330i  [0.00]
You sure about this? I'm asking because you don't have a BMW.
      05-15-2006, 08:36 PM   #5
ward
155
Drives: F
they've been plastic for over 10 years now
      05-15-2006, 09:17 PM   #6
whitecord
trust me i have had that complete engine torn down the a bare block
      05-18-2006, 08:36 PM   #7
ALPINE6SPD
ALPINE6SPD's Avatar
156
Drives: 2010 BMW 328i Sport
leatherette
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills
2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone
2008 AW X3 3.0si: 6 speed Returned
2006 AW e90 330i: 6 speed Dinan Stage 1 Returned
      05-18-2006, 08:40 PM   #8
ksfrogman
ksfrogman's Avatar
574
2006 330i  [0.00]
2006 330i  [0.00]
whitecord, do you know if the ports are extrude-honed from the factory?
      05-18-2006, 11:02 PM   #9
ward
155
Drives: F
Originally Posted by ALPINE6SPD
leatherette
you're killing me alpine!!
      07-02-2006, 02:05 PM   #10
stimpee
Twin Screw Jockey
Drives: 2003 E46M3 SMG
Any suggestions on where I can try to get hold of an engine from a 330 or 325 with intake manifold and accessories?
I need one for a "special" project
Steve
Twin Screw Junky
      07-03-2006, 12:13 PM   #11
RichP
RichP's Avatar
144
Drives: F80
Stimpee,
That ECU is NOT going to take friendly to what you have planned, LOL.
The manifolds are probably not extude honed, they are molded smooth in 2 pieces then either chemically or ultrasonically welded together. There is no more "smoothing" that can take place.
They are plastic because it transfers less heat into the intact tract than aluminum. Also cheaper and lighter.
      07-03-2006, 12:25 PM   #12
ksfrogman
ksfrogman's Avatar
574
2006 330i  [0.00]
2006 330i  [0.00]
I'd like to see one of those N52s bored and stroked to 3.2 liters for a 332i.
      07-03-2006, 06:53 PM   #13
larryn
2148
Drives: '97 332ti, '21 X5 45e, '16 GT4
Hamann does this right now.
Originally Posted by hamann site
HAMANN INCREASED-DISPLACEMENT ENGINE HM 3.2
for Basics 330i
Displacement increase to 3165 ccm
Power increase to 306 hp / 225 kW
to 6700 rpm
Max. torque 347 Nm at 2900 rpm
V/max approx. 279 km/h
Results may vary depending on basis engine,
vehicle equipment, transmission, gear and final
drive ratios, wheel/tire combination, etc.
To get the top power, you need to use the fuel
Super Plus 98 ROZ.
More info can be found here.
I remember another european tuner doing that as well. I just can't place the company.
Btw.. Great sig!
      07-04-2006, 02:30 AM   #14
Raley
Drives: E90
I think breyton is the other company that does the 3.2 conversion
      07-05-2006, 02:24 PM   #15
stimpee
Twin Screw Jockey
Originally Posted by RichP
Stimpee,
What could you possibly mean?!?!?!?!
Twin Screw Junky
      11-20-2018, 04:11 PM   #16
Boorda
Drives: 2011 335xi M-Sport
I am very aware of how old this post is, but since it was never specified exactly what kind of plastic BMW uses I thought I would share this good read....
From the link below.....
Mahle and BMW Specify Air Duct of DuPont™ Hytrel® Polyester Elastomer to Reduce Weight and Cost
Stiff yet elastic DuPont™ Hytrel® HTR4275 is being used in a new two-component air duct from system supplier Mahle of Stuttgart, Germany, that connects the intercooler and throttle body of BMW’s three liter, six cylinder twin-turbo engine.
Materials that Withstand Today’s Hotter Running Engine Systems
stimpee did you ever find you a doner motor?
Fritzer944.50
      11-20-2018, 05:18 PM   #17
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
Ya but what Filament do I need to use in my 3D printer to make trumpet inlets? rolleyes:
Noir883.00
      11-20-2018, 11:54 PM   #18
hassmaschine
3966
Drives: "NBO" 330i
Dude, I totally want to know that!
      11-21-2018, 05:06 AM   #19
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
Look at this stuff, not cheap but they mention Manifolds
"Automotive / Transportation Applications: Ultem™ resins provide automotive manufacturers with a high performance, chemically resistant, thermally-stable, cost-effective alternative to metal that is strong enough to replace steel in some applications and light enough to replace aluminum in others. For applications like transmission components, throttle bodies, ignition components, sensors and thermostat housings,"
I don't think my printer can get hot enough to make this work.
https://www.3dxtech.com/ultem-1010-3...ting-filament/
      11-22-2018, 09:06 PM   #20
AWSB328iM
AWSB328iM's Avatar
397
Drives: 2011 E92 328i M-Sport 6MT
They've been plastic since the E36 came out in 1992.
      11-23-2018, 05:20 PM   #21
nsjames
2440
Drives: 08 328xi Touring
I would give polycarbonate a go in a 3d printer.
it's thermoplastic.
so technically after it's printed it should not melt before it burns. Print temperature is around 280C, and IIRC poly carb doesn't glass until 150ish.
it's about the highest temp plastic that you can run through an average 3d printer, and won't require any kind of post heat like the metallic materials. Also it's way kinder to your nozzle and hot end. The metallic ones will wreck a standard hotend with the quickness. You've got to step up to a ruby nozzle if you're going to use the metal/reinforced filaments.
