09-17-2021, 03:24 PM | #1 |
Rep 37
AC in auto mode
Regarding AC in auto mode, can you tell me how it is supposed to work in terms of controlling fan speed?
On most of my previous vehicles, if I place the AC in auto mode, the fan speed automatically adjusts the airflow in the vents to maintain the desired temperature if needed. I noticed in the X7, although I place the AC auto mode, the fan speed stays constant and doesn't adjust. Am I missing something? |
09-17-2021, 11:57 PM | #3 |
///M SubDriver
1840
Rep 2,785
Drives: 2017 M3, 2020 X7 40i
My experience has been that when in auto, fan speed will vary based on the delta between set temperature and actual temperature inside the X7. That said, sometimes it seems like the "delta" necessary for the fan to increase speed automatically is higher than you would think, and sometimes I end up manually adjusting the fan speed if I want to cool off quicker.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
09-18-2021, 06:27 AM | #4 |
859
Rep 1,009
There are 5 levels of intensity of the fan speed in auto mode. I leave mine on level 2 most of time or level 3 if its really hot out. Advantage to this system is that you don't have fans screaming at you every time you start the car. If it's really hot then I hit max ac for a short time and then back to auto.
09-18-2021, 06:30 PM | #6 |
72
Rep 268
What I've noticed is that if you have it on auto, then the fan speed you set is the maximum it will use. I definitely have noticed the system reduce the amount of air it blows over time, but it won't show on the display.
Also, I think the first two rows share the same AC and blower system, so as long as one zone needs higher airflow, you near the same "noise" from the dash but the amount of air goes down, hence it may still sound like the fans are on high. |
09-18-2021, 06:40 PM | #7 | |
654
Rep 1,602
09-19-2021, 03:26 PM | #8 |
302
Rep 913
farther from the temp, harder it blows. closer it gets, slower it ramps to the temperature so it doesn't fly right by it
and then there's "low", which is where it belongs /lives where it's stupid hot outside
2020 bmw xHippo, v8tt edition
