Bimmerpost
4 Series
Technical Topics Wheels and Tires Help ! Tire Pressures on 795M wheels
      09-13-2021, 08:12 AM   #1
Kevin1973
Drives: 2016 M2(F87) 2021 M340i (G21)
Hello,
I just put the 795M M Performance wheels on my G21 M340i, what is the correct tire pressures on the 225/35/20 (F) and 255/30/20 (R) ? I couldn't find the size on my door sticker, can anybody help ?
Would be appreciated if you could post the door sticker on your door ..
Thanks !
      09-16-2021, 10:45 AM   #2
SP_M3
SP_M3's Avatar
14
Drives: M3(F80), STi Series.White(VA1)
You'd be okay sticking with the pressures you had in your OEM tyres for daily driving (assuming your tyre widths and load index didn't get a dramatic change compared to stock ones).
Pressure is pressure...meaning, for instance, 35psi in 225/35R20 is as same as 35psi in 255/40R19 on the same car(under same weight/load).
///M3 F80
Sold:
STi VA1 Series.White, 330i xDrive G20
WRX VA1, STi GV2, EvoMR CZ4A, STi GDB
      09-16-2021, 11:54 AM   #3
G22b58
94
Drives: G22
I don't know if it is relevant for your model, but for M440i the sticker is shown below. Perhaps you can use the difference to your old sizes as a guideline.
g20
