BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
European Auto Source (EAS)
      11-12-2008, 04:07 PM   #1
///M3Power
Drives: M3
Valentine Installation
Any DIY out there?
Can I see some pics of it installed?
Thanks,
      11-12-2008, 04:32 PM   #2
schnell325
Bored at work....
schnell325's Avatar
887
Drives: 2016 F82 M4 GTS//2022 M235iGC
http://www.e90post.com/forums/showthread.php?t=97545
I hope this is what you need.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      11-12-2008, 09:21 PM   #3
eeesh2u
First Class Privates
Drives: 2006 E90
I'd be careful though...as much as I love the V1, Virginia has been getting a lot of Spectre RDD's, and the newer V1's are VERY detectable, due to a manufacturing change from a couple years ago. If you are going to use an RDD, unfortunately the only stealth options are the Bel STI or STI-r (custom install) or the Escort 9500ci (custom install).
Here's hopin' V1 gets off their laurels and comes up with a solution to the Spectre...its been years now.
      11-12-2008, 09:42 PM   #4
frankzlin79
frankzlin79's Avatar
265
Drives: 2018 M3
My V1 is hard wired through the cigarette lighter adapter, using V1s hard wire kit.
      11-12-2008, 10:52 PM   #5
ScottyGams
Uber-Lee7 Member
ScottyGams's Avatar
45
Drives: E92 M3
virginia is no joke!
      11-13-2008, 06:44 AM   #6
eeesh2u
Drives: 2006 E90
      11-13-2008, 11:18 AM   #7
batchelorc
batchelorc's Avatar
51
Drives: Deez nuts
Probably a stupid question, but can the guys in VA detect a valentine 1 that is turned off?
      11-13-2008, 12:06 PM   #8
endofanera7
endofanera7's Avatar
No_Country
513
Drives: 08 JB E92 M3
Yes, with their eyes !
      11-13-2008, 12:23 PM   #9
Irb Digital
Irb Digital's Avatar
13
Drives: ///M E90 MANual Jerez
      11-13-2008, 02:14 PM   #10
///M3Power
Drives: M3
Originally Posted by schnell325 View Post
Very nice!
      11-13-2008, 02:37 PM   #11
SS32
SS32's Avatar
156
Drives: 2008 M3
Check the link in my sig, that DIY leaves out a couple things.
      11-26-2008, 10:20 PM   #12
FrenchBoy
FrenchBoy's Avatar
France
233
Drives: '16 F80 M3
I just hardwired my Valentine 1 using the fuse tap method. Worked like a charm. It is much simpler than I thought it would be.
I initially tried the DIY mentioned above but after trying to remove the damn light fixtures without success (and actually cutting my finger while trying to reach for the metal clip) and hearing about the possible issues with the sunroof operation, I decided to go the fuse tap route instead.
Only part I had to buy was this one
Let me know if anyone needs photos of the install and I will try take some. All and all, a simple install. Also it does not require any drilling contrary to a E90 DIY states.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates
Previous: 2009 E90 M3
      01-03-2009, 10:18 AM   #13
Gladius
Two Wheels or Four?
Gladius's Avatar
92
Drives: '18 Perf Edition m240i
If you use the fuse tap method, do you still need to use this inline fuse connector included with the V1?
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      01-07-2009, 09:05 AM   #14
Gladius
Two Wheels or Four?
Gladius's Avatar
92
I ended up using the fuse tap on slot 7, the homelink slot on my E90. I kept the inline glass fuse (1 Amp) and put a 5 Amp fuse in the piggyback adapter. Seems to work just fine.
Search this Thread:
Advanced Search
m3post
