09-07-2021, 04:16 PM | #1 |
137
Rep 718
Drives: N/A
Rear bumper tab broken… is it fixable
Hi,
Looks like I have really bad luck on this 5 days old car… Since I can't install the MP CF diffuser, I try to remove the bumper to install it. Remove the screws and try to pull the bumper out on one side. And this tab broke… Now I want to find out is this fixable. I don't want to replace the whole bumper… Can I use super glue to fix it? What is the correct way to remove the side? I unscrew the screw and I pull a little bit harder and it break… DO I need to pull down the black plastic then pull it out?
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
09-07-2021, 04:20 PM | #2 |
4207
Rep 5,728
Drives: 2019 M2 Competition
Superglue that bitch and find a good installer for the future
09-07-2021, 05:34 PM | #3 | |
447
Rep 241
Hell maybe even polyeurethane pipe fitting glue. That stuff melts the poly to the mating surfaces. That actually might work better than JB Weld. https://www.homedepot.com/s/polyuret...sealant?NCNI-5 |
09-08-2021, 10:34 PM | #4 |
2356
Rep 4,254
JB weld would work fine for that. Wouldn't sweat it. Don't use that plumber glue or you won't ever get the ABS parts apart again. Carefully mold the JB weld at the cracked spot and put the bumper back together after it hardens.
///M Power
.Slug447.00 |
03-17-2022, 09:18 PM | #5 |
67
Rep 127
What did you end up doing? Just broke both sides on mine, and lost the pieces that snapped off.
I just re-installed everything and it seems to be holding fine…curious to know how yours is holding up. |
03-17-2022, 09:28 PM | #6 |
526
Rep 1,078
Note to self never remove the rear bumper lol
