09-03-2021, 09:48 PM | #1 |
41
Rep 78
BM3 stage 2+ e30 log big stumble afr's
Just tried out the e30 log after swapping to a Dorch stage 1 HPFP to go with my
CSF intercooler, EVO racewerks charge pipe, injen intake, evo racewerks catless down pipe. Running 3.5 gallons e85 8 gallons 93. I've noticed before I tried Ethanol that the map 3 93 octane didn't feel quite right and ended up going back to the stage 2 93 map until tonight. I reflashed and mixed up the fuel and did a 4th gear pull. Everything felt fine and then i had a bog during the run and then it started pulling and then bog again. I stopped the run and returned home. After looking at the logs you can see a big spike of the afr for each bog that happened jumping to 16.x for a second then pulling back down to normal 13.x boost actual is at 21psi which seems high and the actual fuel pressure is higher than the target during both bobbles. the timing started going crazy so I'm wondering if this is a boost cut and thats making the afr read like i'm lifting off or a spark plug failing... which i would think would result in a rich reading. (Spark plugs are the one step colder gapped to whatever BM3 was recommending. Swapped 10k miles ago and not had an issue until this new stage2+ came out with new fuel pump. Again stage 2 93 runs great) https://www.bootmod3.net/log?id=6132...0b433146aa88af any help is appreciated as I would like to run this setup but I have topped off with octane booster and will run the normal stage 2 tune until I either get a custom tune done or this can be resolved. super sketchy feeling either way. |
09-04-2021, 01:21 PM | #4 |
41
Rep 78
I still have the stock tmap and have that selected as oem.
Hardware doesn’t seem to be the issue because nothing is out of the ordinary, iat was 70 something, fuel pump was chugging along, boost holding strong and no fault codes, Just a big ass hickup which was weird. I’ll try and get it on a Dyno and pull the plugs just to make sure but seems like it should just work lol |
09-04-2021, 02:36 PM | #5 |
2824
Rep 3,699
It’s hardware.
Read up in some of the other Stg 2+ E30 threads, it’s probably the TMAP. You’re already hitting the stock TMAPs boost read limit, so it needs to be changed anyways. Change it and add more E85, and you’ll be fine. Separately, I had issues with BM3 recommended plug gap that went away when I went back to stock gap, but those were very tiny intermittent hiccups, not big ones. Last edited by ZM2; 09-04-2021 at 06:05 PM.. |
09-05-2021, 07:08 AM | #6 | |
41
Rep 78
09-07-2021, 06:59 PM | #7 |
124
Rep 261
09-07-2021, 07:48 PM | #8 |
2824
Rep 3,699
09-07-2021, 08:04 PM | #9 |
124
Rep 261
