08-27-2021, 04:25 PM | #1 |
277
Rep 365
Drives: 2023 BMW M240i xDrive
So on my 228i GC there is that little hole on the turn arm for the gas lid and I assume that's where you put the tip of the cap to hold it. And on my X3 I put it there and it locks in perfectly and fits as it should. But for my 228i when I put it in it doesn't stay it falls out and I try to put pressure and push it in but it stays but not as secure as my X3 and I don't want to force it too much and break the lid. So has anyone noticed this I'll attach a photo soon.
08-27-2021, 11:24 PM | #2 |
Rep 5
Thanks for the reminder. This has disturbed me whenever I fuel up but then I drive away and I forget to fix the issue. Just ran a 9mm bit down the hole and the cap now fits.
Cheers |
08-28-2021, 10:34 AM | #4 | |
277
Rep 365
08-28-2021, 10:59 AM | #6 | |
277
Rep 365
08-28-2021, 10:14 PM | #8 |
Rep 5
Probably better to skim a bit of the plastic off the cap as has been mentioned above as the cap is easier to replace if it goes wrong. Below is a photo of the cap sitting in its hole after drilling with a 9mm bit.
cheers |
08-29-2021, 12:31 AM | #9 | |
19
Rep 44
I had similar issue it was holding but not that great. Did the same trick and so far all good |
08-29-2021, 07:16 AM | #10 | ||||
277
Rep 365
08-30-2021, 06:46 AM | #11 |
142
Rep 291
Just checked mine and I think the hole is deeper:
Series 2 GC M235I xDrive, Snapper Rocks, Pro, Tech and Drivers Assistant Packs, 19" 557M Wheels. DTUK Tuning Box.
08-30-2021, 09:58 AM | #12 |
277
Rep 365
