Has anyone used this swaybar kit?
08-20-2021, 03:31 PM | #1 |
386
Rep 59
Drives: 2011 BWM E92 LCI+23 other cars
I have an E92 LCI. I’m looking for some feedback. For now, I’ll be installing it with stock springs and shocks. Thanks!
https://www.bimmerworld.com/Hotchkis...M-Car-Set.html |
08-21-2021, 12:49 AM | #2 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Changing the rear sway bar out is overkill even on modified suspension imo, plus a pia install. I would just look for a front one, but for when you change other things too.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
08-21-2021, 01:04 PM | #3 |
386
Rep 59
The last thing I want to do is just change the front one. It already pushes the front end under acceleration in the corners. I’m looking to do the opposite. Get more weight on the front end, and have the car run flatter through the corners. The Hotchkis kit will do both those things. My biggest question is, what it will be like with using the stock springs and shocks. I have never done just a sway bar change before.
08-21-2021, 01:29 PM | #4 | |
1691
Rep 3,652
I think you’ll find that a lot of your issue is the rest of the suspension. A few degrees of camber up front goes a LONG ways and a stiffer bar can really sharpen the response. So what you wish of course but IMO there’s a reason most people leave the rear bar alone. I’ve seen a number of people to back to stock even though it’s a pain to mess with. |
08-21-2021, 03:04 PM | #5 |
299
Rep 532
you need better and or wider rubber in front tires and some camber along with a front sway bar to really see the best benefits. been running 255 upfront with swaybar only, it's great
08-21-2021, 03:59 PM | #6 |
3060
Rep 3,914
Have a look at the spring rates you're installing, compared with stock. From there you can probably get a feeling for how much bar you want to add, and where.
Adding some neg camber to the front does help a lot! |
