Passenger mirror stopped working
08-19-2021, 08:13 AM | #1 |
858
Rep 1,363
Drives: 09 E90 335i M-Sport 6MT RWD
So I got told earlier this week that my brothers E90 (09 328) is passenger mirror tilt down stopped working. Digging in none of the power mirror functions work and it doesn't adjust(its a non folding mirror) but I am unsure about the heated part as its summer.
I checked the fuses and they're all fine, also swapped the mirror motors with 2 spares and nothing. Is there anything I can possibly be overlooking? |
09-07-2021, 08:18 AM | #3 |
858
Rep 1,363
Nope with the switch to the passenger side it still does nothing.
Scanned it with a schwaben and got a '9CC4' code: Communication disturbed with passenger side mirror in the FRM section. Now that makes sense. I reset the FRM and that changed nothing so my guess is now down to wiring somewhere. |
09-14-2021, 12:19 PM | #4 |
Driving cars and riding bikes really fast
285
Rep 1,002
Dumb question: Did you clean the wiring connections for the mirror? This is a common issue on older 3 series.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
09-14-2021, 01:42 PM | #5 | |
858
Rep 1,363
I've thought about checking that next and then seeing if I'm getting power there even. Just have to get some time to get the door panel off |
09-15-2021, 07:34 AM | #6 |
285
Rep 1,002
The connection from the wire to the motor, behind the glass. It gets water in the connection (bad factory design). Most guys unplug it, add a f**k ton of dielectric grease, and it fixes it. My passenger mirror has been acting a fool as well That's the most common fix. Maybe it helps.
09-15-2021, 07:36 AM | #7 |
858
Rep 1,363
Ya I did check that; I pulled off the glass and swapped 2 other motors to see if it was bad. Sadly no difference
southpaw030618.00 |
09-24-2021, 09:14 AM | #8 |
858
Rep 1,363
So was driving his car again and the Autodim rear view also doesn't work anymore (both of these features were factory with the car)
His car is an 09 (11/08 build) so it has the latest fuse box style. I checked 63 and 66 (the ones that match up with passenger mirror) again and they still look good. Is there another fuse I happen to be missing? |
09-26-2021, 11:40 AM | #9 |
463
Rep 2,768
when you swap motor be sure you swap version with LIN bus
because versions with memory require LIN bus same goes for folding and autodim mirrors
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
Suvorovo257.00 |
09-27-2021, 07:27 AM | #10 | |
858
Rep 1,363
So any car that has memory (LIN) will have a different motor than non-mem correct? I guess Ill try to source another motor and check. The mirror is just heated + shadowline; Not folding or autodim side mirrors |
Suvorovo257.00 |
12-14-2022, 09:01 AM | #12 |
858
Rep 1,363
Not yet, Its either a fault in the wiring or FRM; but haven't had the spare time to deal with it
12-17-2022, 11:14 PM | #13 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
If you want another side mirror for the time being I have a set from an iS fs
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
