11-10-2008, 12:31 AM | #1 |
Rep 38
Anyone Know how the Oil Level Sensor Works?
I know there are A LOT of threads on the oil level issue.
Here is my story: Oil level at top arrow when new. Dropped to 8/10 mark at 1200mi service. Picked car up from dealer, level at mid-mark. (I questioned them and they said "That's where it is supposed to be, at the half way mark.") Not happy with answer. I drove the car for 150 miles and added 250ml. No change. Drove the car for another 150 miles and added an additional 250ml. No change. Then after approximately 800 miles of driving following the service (mileage then 2K) the oil level read at the top arrow. Yes, the manual says that the sensor does not detect additions less than 500ml. What I would like to know is HOW does the sensor determine the oil level and WHY did it take roughly 500 miles for it to detect that I had added 500ml? The car now has 3150 miles and still reads at the top arrow. I would appreciate any logical explanation for this. Thanks. |
11-16-2008, 08:16 AM | #2 | |
Faster
Rep 132
Drives: M3 Coupe Melbourne Red/Black
03-23-2009, 06:41 PM | #3 |
Rep 38
Latest Update:
Around 6K, the gauge read at the 3/4 mark. I opted to take the car in for an oil change at 6600 miles (5.5K after the initial break-in change). Same story, I picked the car up and it was reading at the half mark. Again, I assume that the gauge, if linear, reflects a total range of approximately one liter. I drove the car for 100+ miles and got the same reading. I added 500 ml. I drove the car for two days, approximately 55 miles. When I pulled into my garage I checked the gauge and it was showing the rotating "clock" symbol, indicating that it was recalculating the level. It then displayed at the top arrow mark, with the OK indication. Based on this experience I will make the following assumptions: The service technicians are very nervous about adding too much oil, so they play it conservative and fill it slightly under the maximum capacity. For some reason (and this is where I am still confused) the sensor does not seem to register small amounts of oil added in a timely fashion. Referencing my initial post, it took approximately 800 miles before the gauge reflected the 500 ml that I added incrementally. This time, I added the 500 ml all at once (as noted in the manual) and it registered after approximately 55 miles. Better, but I still fail to understand why it would not register after the oil was up to full operating temperature, say after 15+ miles of driving. Bottom line: I check it each time I drive the car. There's plenty of oil in there and as long as no flashing red lights come on, I'll live with it. My intuition tells me that the next iteration of M3 with have this dialed in better. I'm certain that this issue is no secret to BMW. AC |
03-24-2009, 10:28 PM | #4 |
597
Rep 5,448
good luck. mine read add one quart - luckily I was hesitant and added only q/2 quart and after a few miles it read full. If I had added the full qt I may have gotten the overfill error.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
03-29-2009, 01:02 PM | #5 | |
Rep 38
It was based on previous experience (adding 500 ml at the half mark that eventually brought it up to the top arrow). Given the enigmatic operation of the oil level sensor it appears that it will always be a matter of making the call to add, or not. I'm going to see if I can get any information from BMW on this... AC |
03-29-2009, 01:07 PM | #6 |
72
Rep 1,172
Just empty the 1lt bottle when prompted to do so. Don't add fractions as you may end up ovefilling (= trouble). That's what I was told by my dealer, that's what I did 2 times already with no issues. There is enough oil in the sump for a while even when the oil level indicator shows minimum.
