I'm getting a hot and cold side charge pipes. Will it help my car run better on BM3 s |
08-08-2021, 02:14 PM | #1 |
21
Rep 93
Hey guys so i'm getting both hot and cold side upgraded charge pipes because my shop recommended them since the stock ones are horrible. I also have a VRSF 6.5" Competition Intercooler. With these upgrades, will it make my car run a little better when i run my BM3 E30 and BM3 Stage 2 maps?
Let me know! Thank you so much |
08-08-2021, 02:42 PM | #2 | ||
Rep 27
Adding the BM3 tune will make a very big difference. I also have an Active Autowerks catted downpipe and so can run BM3 stage 2 multimap. Compared to stock It pulls very hard indeed - smokes the tires in first and second, plus you get the anti-lag feature which is quite the thing, although I wish they'd set that up to use the 2nd position in cruise control (requires a light touch instead of simply pushing it). Definitely enjoying the change that it all makes but now trying to figure out running E30 fuel to see if I can get more power. Hope this helps!
Rowie.
08-08-2021, 04:16 PM | #3 | |||
21
Rep 93
08-09-2021, 09:18 AM | #4 |
Joint Chiefs of Staff
24263
Rep 190,950
Charge pipe and Boost pipe won't add any power regardless of which map you run.
The shop is asking that you upgrade them because it's a matter of time before they fail and start leaking causing a loss in power. if you car run better after the upgrade, that's a sign that the stock ones were leaking
