Are BMW's really that fragile??
04-26-2006, 09:37 PM | #1 |
Rep 25
Quote from LeftLaneNews: "How much will maintaining a high tech car cost you?"
"Of course, when it comes to high repair costs, gadgets aren’t the only problem. High-tech manufacturing methods can also be very costly. In October, we cited an LA Times report that looked at BMW’s construction methods that can make for costly fender-benders. For example, the new BMW 5-series and 6-series models are constructed with “many of the same techniques you might find at the Northrop Grumman F-18 assembly plant in El Segundo.” These new cars use rivets, epoxy adhesives and aluminum structures in the front end to save weight. The BMW system features an aluminum firewall and aluminum frame rails that extend forward, all riveted and glued to the rest of the car’s steel structure. The entire front structure weighs just 100 pounds, giving the car a perfect 50/50 weight distribution. Unfortunately, due to the limitations of aluminum, if the front end of one of these new Bimmers gets tweaked by more than a millimeter in a relatively light front collision, the entire front structure might need to be replaced." ok, i knew aluminum was malleable, but DAMN! could this really be true?? could a small fender bender harm the chassis?? as well, aluminum unlike most metals gets stronger when oxidized, and anondized aluminum is quite strong....plus i doubt BMW makes their bumper out of pure aluminum and not some sort of alloy |
04-26-2006, 09:48 PM | #2 |
Moderator
618
Rep 10,858
This is the 5/6 series. Aluminum composite cars are nice, but, like carbon fibre cars, they are not easy to repair.
No such problem with 3 series. |
04-26-2006, 09:51 PM | #3 |
E90post addict
17
Rep 489
04-26-2006, 09:54 PM | #5 | |
Rep 25
thanks for the article...it helped a lot...but personally...for me there are only 3 bmw's i'm concerned with....the 3 series, the m3 , and the m roadster....anyone have any info on the body of any of those? |
04-26-2006, 10:12 PM | #6 |
17
Rep 710
Drives: 02 M3/RRover Super
You may find this interesting if you are thinking about a 335.
http://www.e90post.com/forums/showthread.php?t=18359 |
04-26-2006, 10:21 PM | #7 |
Freude am Fahren
338
Rep 5,254
One of the top BMW-only body shops in the New York metro area (Small Cars) closed about a year and a half ago, the owner lamenting that he felt that the new BMW ranges were not repairable to the standard he would normally use (his work was considered to be equivalent to factory).
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
04-26-2006, 10:54 PM | #8 |
Bimmer Manual all the way
68
Rep 1,811
Unfortunately, my experience with 3 series says yes. Modern post e46 beemers are quite fragile when it comes to 'plasticky parts' in particular e46 chrome or black window sill trim kept coming out in my e46 even after changing the catches.
there is a poorly designed black plastic corner piece that is situated under and behind the e90 front seats. it popped out 2 weeks after i collected the car. my dealership initally refused to change it saying it was wear and tear and somebody knocked it off! Also my rear windscreen rubber was loose after 1 week. so beemers in my opinion are still prone to fragile body parts, dodgy QC and some plastic parts could be better designed. |
04-26-2006, 10:58 PM | #9 | |
40
Rep 470
Same here. My rear windscreen rubber has been always loose and the dealer fixed it last week and it's gotten loose again.
04-26-2006, 11:09 PM | #10 |
hotsand5
49
Rep 806
I do think that the new 3 uses the same materials as the 5 and 6 for the engine cradle, frame rails, etc. That is what the guy at the BMW certified body shop told me while my car was there after the accident...hmmm...and yes, at 35mph the car was totalled after an off-set frontal collision (one of the most severe impacts on the cars structure). I'm sure that as soon as insurance companies start figuring this out, our rates will get jacked! After the accident everybody told me that is would not be possible for them to total a $50k car for just frontal damage....sure enough, they were wrong.
-2006 BMW 330i-Sapphire Black- Tera Leather-Aluminum trim- 6spd manual- Sport- Premium- Cold- Navigation- Euro. delivery
-2005 Yamaha Warrior 1700 102cu" |
04-26-2006, 11:54 PM | #11 |
36
Rep 344
I managed a bodyshop in NY Metro area for year and a half. We were authorized and did dealer work for nearby MB/BMW/Volvo/Jaguar. Also Allstate/Geico/Farmer PRO Shop.
I left in 2003, but by that time already we were already dealing with aluminum frames and structures in some of the higher end vehicles. After having to reequip the shop to deal with all of this, let me be the first to tell you a car is almost never the same after a serious hit. You can get it near perfect sometimes, but it's always just a little off - never the same. It's hard enough to work with the myriad of parts and sub-assemblies, but the insurance companies are always hunting the mighty dollar asking shops to straighten structural panels rather than replace. We were once forced to straighten, bondo and paint a floor plan that looked like a crumpled up piece of aluminum foil. Insurance company refused to pay to replace. A car like this in a rear colission again will definitely not hold up to it's original spec. <- one example of hundreds. All of this of course is referring to hard structural hits and not your every day cosmetic bullshit. |
04-26-2006, 11:54 PM | #12 | |
36
Rep 344
04-27-2006, 12:00 AM | #13 |
36
Rep 344
One more story of a younger stupider me --
Borrowed my sister's 2000 328ci (e46 correct?) to go up to the gf at the time's house. Ended up hitting a patch of black ice, slamming into a cement barrier at a head-on angle at about 35-40 miles per hour. The car was torn down and was very close to being totalled out. They decided to repair against our wishes. The car looked beautiful - hard to tell it was ever hit. Never did drive just right the same. Rear tires were always balding unevenly. Car was brought back to the shop multiple times and checked on the frame machine, aligned, all tires balanced and speed tested .. everything showed up ok, but it was never right. Very happy to return that lease. Most important thing though, I walked away from the accident without a scratch. I don't remember for sure, but I don't even think I was wearing seatbelt at the time. |
04-27-2006, 05:17 AM | #14 | |
Rep 61
04-27-2006, 05:44 AM | #15 | |
Rep 7
The RWD 3 series uses Aluminium. The XI uses steel. |
04-27-2006, 07:28 AM | #17 | |
1312
Rep 10,185
BMW if you are reading, I need a job, Please. |
04-27-2006, 07:29 AM | #18 | |
1312
Rep 10,185
04-27-2006, 07:31 AM | #19 |
1312
Rep 10,185
I asked our BMW only body shop here, and they said they have no problems with the Aluminium in 5 and 6 Series.
They say you need special tools and extra training for the staff, but after that there is no problem. Besides, if they were so expensive to fix as that article says then Insurance companies whould have massively rased their rates, which they have not
04-27-2006, 08:29 AM | #20 | |
Rep 158
Drives: 2006 325xi
04-27-2006, 10:30 AM | #21 |
Rep 7
It looks like the some of suspension components on the XI are steel. Probably not the frame rails.
• Extensive aluminum componentry for low unsprung weight.This improves the suspension’s response to bumps and other road irregularities; it can markedly improve riding comfort and, on any irregular road surface, handling as well. Aluminum components on each side include – • Both lower arms (forged aluminum) • Steering knuckle (also forged) • Brake caliper (not part of suspension, but part of unsprung weight) • Brake shield (a stamped piece; also not part of suspension, but part of unsprung weight). In addition, the subframe that carries the front suspension is of aluminum, as is the steering rack; these are not unsprung components, but do contribute to overall weight reduction – and being up front, also to the “typical BMW” near-50/50 weight distribution. More elaborate than the previous steel one, the new subframe adds rigidity, enhances steering precision and is also an integral element in the vehicle’s management of energy in a frontal crash. The previous 3 Series’ aluminum components were its single lower arm and brake shield; thus there is more extensive use of aluminum in the new system. All things considered, the new front suspension represents an enhancement of the 3 Series’ already legendary road qualities. Note: The 325xi and 330xi models have steel lower arms, and a steel subframe plus an aluminum thrust plate that reinforces the main structure in the area of the subframe’s attachment.This arrangement provides additional strength for the xi models’ driven front wheels.Thus it cannot be claimed that the xi models have aluminum suspension. |
04-27-2006, 03:50 PM | #22 |
Rep 20
I got in an accident last friday, and I was floored when the insurance inspector told me there was $10k worth of damage to my car when the other car needed a new bumper at most, and this was at 10mph max.
'06 330 Sparkling Graphite, Grey Leather, Alu Trim, SP, PP, Auto
