x-Drive staggered setup
07-27-2021, 01:05 PM | #1 |
Novice Enthusiast
15
Rep 75
Drives: 2010 BMW 328i e92 ULEV 90k
Garage List 2010 BMW 328i x-Drive [0.00]
2012 Ford E-350 [0.00] 2009 Cadillac DTS LUX [0.00] 2003 Mercedes Benz ... [0.00] |
XI Staggered Tire Calculation Tables https://www.e90post.com/forums/showthread.php?t=1050762
I have come from this post. The post shows a table that outlines all of the rotating speeds of all the different tire sizes. Okay, so I bought my car with 235/40 ZR18 on the front and 245/40 ZR18 on the rear. Now, with my very minimal knowledge of AWD drivetrains I understand that different rotating speeds from front to back (if it isn't within the 1.0% threshold) can cause issues for the center differential. Having said all of that according to the above mentioned post and table my car with the sizes I bought it at is sitting at a 1.2% which is above that threshold. Was the previous owner a dummy that chose looks over research. Is that .2% really that detrimental? Idk anything about nothing. I really don't want to find out that because I didn't reverse this my center diff is shot. Any help please!
‘10 328i 6AT (GM 6L45) AWD
‘03 SLK 230 5AT RWD ‘09 DTS 4AT FWD 12 Ford E-350 |
07-27-2021, 02:39 PM | #2 |
206
Rep 525
What tire pressures do you run?
Do you have xDelete? Is the wear on the tires even or uneven? (front vs back) When was the last time you changed your transfer case fluid? ("center diff fluid") Buying the right size tires would be the best solution. xDelete or drive shaft delete (at least in the summer) would be the next best, except then you don't have AWD anymore. If the backs are well worn and the fronts aren't, then that could help change the tire size that last 0.2%. If the backs are underinflated and the fronts are overinflated, then that could help change the tire size that last 0.2%. Finally, and this is always a good thing, change the transfer case fluid. If the thing is going to be slipping more than normal, you definitely want it chock-full of synthetic friction modifiers in modern GL-4 fluid. The fluid in the transfer case is meant to be sacrificial. It wears out instead of the transfer case components wearing out. If the fluid is all worn out, it will start accelerating wear of the transfer case, even if you were <1%. So change the fluid anyways asap if you haven't already. |
tgeho_e9215.00 |
07-27-2021, 02:43 PM | #3 | |
Novice Enthusiast
15
Rep 75
07-27-2021, 02:44 PM | #4 |
638
Rep 766
It'll be fine. BMW's use a wet clutch to push torque to the front axle. It's always slipping. The drivetrain can probably tolerate a much larger differential than the computer will before throwing errors.
Sometimes a bolt is just a bolt.
07-27-2021, 02:46 PM | #5 | |
Novice Enthusiast
15
Rep 75
07-27-2021, 02:49 PM | #6 |
Novice Enthusiast
15
Rep 75
Other than a fluid refresh, do you think I'll be fine running this set up? I really like my Enki XM-6s.
07-27-2021, 04:45 PM | #7 |
638
Rep 766
If the computer isn't throwing big red "4x4" error messages in your face, then it's within the engineering tolerances from BMW. The T-case gears the front driveshaft a smidgen taller than the rear. Larger diameter rear tires will decrease this differential a little bit.
It could result in a non-trivial decrease in torque delivered to the front wheels... but I'd place my bets that the driveline map takes relative wheel speed into account when deciding how hard to clamp down on the wet clutch. Can't say for sure, but it wouldn't surprise me if it not only works perfectly, but doesn't add any accelerated wear. Really I would only expect a problem if the mismatched tires were to perfectly match the front/rear T-case gear ratios. If they were too close, or went the wrong way (larger front tires) the wet clutch might start to chatter in the former, or it would actually apply reverse torque to the front wheels. That said I imagine the computer watches the wheel speed inputs and throws "4x4" errors if it's too far off. The wet clutches are very robust. Mine had 295k miles on it and worked perfectly as far as I could tell. I swapped it for a low mileage T-case because the front output yoke developed a bunch of slop (I blame a previous owner for not changing a bad front driveshaft U-joint) Fluid maintenance is a very good idea.
Last edited by Brian86; 07-27-2021 at 05:56 PM.. Reason: Mixed up shorter/taller until I proof read |
07-28-2021, 04:43 PM | #8 |
152
Rep 165
