07-12-2021, 12:02 PM | #1 |
Novice
311
Rep 698
Oil drain plug gasket question
So whenever I was doing an oil change, I torqued the oil drain plug a bit too hard and saw a small bang go off (kind of like a firecracker) by the drain plug. No oil is leaking but would oil pressure be low and should I replace the oil drain plug gasket asap?
07-13-2021, 07:17 PM | #2 |
1660
Rep 4,903
If you over torqued the bolt, it won't effect oil pressure, but it could leak.
Not sure why you would hear a "firecracker" sound unless you slipped off the drain bolt? |
07-14-2021, 06:53 PM | #3 |
Novice
311
Rep 698
Yea I don't know why either I didn't overly torque it but definitely to the point where a crackle just appeared out of nowhere
