2011 335d HK/L7 Suddenly No Sound!!
06-06-2021, 12:28 PM | #1 |
Rep 78
Hey guys, in dire straits with this random issue. Got in the car yesterday, fired it up, immediately a horrendously loud screeching sound came from the speakers, stopped, then a different more "electronic" sound, just as loud, than nothing. Checked Aux cable, was slightly pulled out of the port. Not sure how this could've caused this, but the symptoms are:
No sound whatsoever from speakers; no radio, Aux, phone, dash displays a message saying "Attention! No warning tones" I. E. It isn't detecting a way to play interior chimes/etc either. Idrive functions normally except for all settings having to do with audio; when I try to adjust any of them, there's a long delay, 20 seconds or so, before my adjustment with the Idrive wheel takes effect. I tried checking all the fuses that I believed to be related to the audio system, the 30amp amplifier fuse, etc. And all are fine What could possibly be causing this?! Everything else in the car works fine Last edited by thewheelm4n; 06-06-2021 at 10:59 PM.. |
06-18-2021, 09:35 AM | #2 |
Tinkerer
83
Rep 532
Sounds like your HK amp has gone pop.
All the symptoms and the "Attention! No warning tones" means that your amp is not being seen on the MOST bus, so I suspect that its dead, or non functioning. Have a look in the boot (the trunk) and see if you have water in the right hand side, thats probably whats happened.
2014 F25 X3 335d M-Sport:
06-18-2021, 02:56 PM | #3 | |
Rep 78
06-21-2021, 10:08 AM | #4 |
Tinkerer
83
Rep 532
Nice one mate
Might be an idea to make sure its coded (to your car type) as the L7 amp is available on lots of BMWs Its just coding to make them work 100% for the interior sound staging. SO, if the amp came from an x5 and you are putting it in a e92, the staging will be for a bigger interior volume and the timing between the speakers might be off.
06-21-2021, 01:13 PM | #5 | |
Rep 78
It seemed to cut out twice last night on me though, when I was using PDC to back up it didn't have any sound for a second, then came back, what could cause this? |
06-22-2021, 03:14 AM | #6 |
Tinkerer
83
Rep 532
Probably does not need coding
Hmm, maybe you have a another module, check and see if the car has any error codes logged
06-24-2021, 06:22 AM | #7 | |
398
Rep 1,579
Tags |
e90, no audio |
