05-31-2021, 03:36 AM | #1 |
Rep 4
DSC Module error
Hi, i'm new on this forum, my name is Rares.
I have Launche Pro V2.8.2.162 and PSdZData 4.28.21 I coded yesterday the DSC Module: C_Funktion_LaengsMomentVerteilung_aktiv_e to nich aktiv, to disable for a little time the xDrive. This morning i tried to change back the code to activ but the DSC Module appear in grey without any green arrow ( BTLD_000... ; HWEL_000... ; SWFL_0000). I have a christmas tree on dashboard (abs, pdc, acc...) . I don't have a backup of SVT only of VO. Now i have in gray i can't code the DSC Module, Code, Read Coding Data, Code FDL, Detect CAF for SWE. |
05-31-2021, 04:01 AM | #3 |
Rep 4
Yes, i have already activate FA, nothing changed.
Because i had the screen in a hurry, but with the FA active nothing change. Last edited by Rares_001; 05-31-2021 at 04:07 AM.. |
05-31-2021, 04:19 AM | #4 |
588
Rep 2,302
Well, I thought so.
So now you need older psdzdata or a newer E-Sys version because E-Sys 3.27 doesn't work correctly with psdzdata 4.28. Here you can download E-Sys 3.31 https://mega.nz/file/AHB32SyQ#NLGu68...m5GevHEgckkJCs Install it and start E-Sys directly from it's own folder C:/EC-Apps/ESG Don't try to start this version with the Launcher, because it doesn't work. Then try again to assgin the CAFD. You can use this version only for your current problem. For FDL Coding use again your old version 3.27 + Launcher Pro 2.8.2. |
05-31-2021, 04:26 AM | #5 |
Rep 4
Ok, thanks so i have to download a newer or older psdzdata, download Esys from your link and assign the CAFD.
How i assign the CAFD, are the first times with Esys. Do you have the right version of Psdzdata download link? Last edited by Rares_001; 05-31-2021 at 04:36 AM.. |
05-31-2021, 04:44 AM | #6 |
588
Rep 2,302
You can use your psdzdata 4.28 but together with my E-Sys 3.31 from my link.
To assign a CAFD mark the DSC (like in your picture), then on the right side "detect caf for swe". A new window opens and you have to choose a CAFD. Choose the bottom one or the CAFD with the highest numbers ( all CAFD there are for the DSC). Then hit the button "Code". That's it. Maybe you have to clear the error memory after that. Never hit the button "Code Default Values"!!! |
10-27-2021, 01:32 PM | #8 |
112
Rep 212
