11-01-2008, 07:21 PM | #1 |
108
Rep 1,291
Overfilled engine oil@@
Picked up the a black sedan last night and went out to drive a big this afternoon. Found that the oil level is too high and oil leaked out from the engine. I guess I should be going back to visit the service department so soon@@
11-01-2008, 11:23 PM | #2 |
125
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Where did the oil leak from, what part of the engine. It's a sealed system therefore any leak is a bad sign.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
11-01-2008, 11:41 PM | #3 |
108
Rep 1,291
it's from the cap where u can add in more oil. Dont know if this is too bad. Was asking a frd who does mechanical works for toyota and he told me this is not too big of problem nothing to worry about. I guess I will have to wait until Monday to figure it out then.
11-02-2008, 12:01 AM | #4 |
108
Rep 1,291
I forgot to take some pictures at the first place. Instead I cleaned it up and damn it it's not leaking out again@@ but oil level indicator still shows way over the maximum point.
11-02-2008, 01:19 AM | #6 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Wow. I guess they REALLY overfilled it.
11-02-2008, 01:50 AM | #7 |
108
Rep 1,291
I know man!! The indicator shows the level is on top of the scale with MAX display on the side!!@@
Tmr is Sunday and the service department will be closed. I was planning to go out to enjoy the new ride before heading back to busy Monday@@ Damn it! now I am not sure if I should drive or not.@@ |
11-02-2008, 01:03 AM | #8 |
4th down; 4th quarter? Renegade.
87
Rep 3,850
Unless there is oil leaking from the actual engine somewhere, I would ASSume that he spilled oil when adding AND overfilled it.
11-02-2008, 07:53 AM | #10 | |
140
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
Then don't drive it unless they tell you to bring it in. I had an X5 that was overfilled, I rang the dealer and they came around put a tub down the diff stick and sucked out a couple cup fulls of oil. I know you don't have a dip stick in the M3 but I would contact them first.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
11-02-2008, 09:30 AM | #13 |
Rep 25
When you cleaned the spilled oil and noticed it came out under the reservoir cap, did you notice if the rubber gasket under the cap was off the cap or loose from the cap? It seem like that is a common problem that the technician just cannot put the cap on correctly. You should check that the cap is on correctly everytime the technician changes your oil.
2011 F25 X3 35i, AW 2008 E90M3 AW, bone stock (Sold) 2002 M Coupe TS, GC S/A coil overs, PF05 pads, Toyo RA1 1998 M3/4 AW sold |
11-02-2008, 02:31 PM | #16 | |
108
Rep 1,291
04-01-2009, 03:39 PM | #17 |
Sleepy Member, wishing I was on the road.
34
Rep 280
so i guess everything was fine with this?
2003 Ducati '996
2008 M3: Sparking Graphite, Red Fox Standard, 19s, Premium pkg, Tech pkg, Premium Enhanced Sound, HD Radio, Heated Front Seats. |
04-01-2009, 04:05 PM | #18 | |
684
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
right @ MAX is ok, just don't want more than that.
04-01-2009, 05:00 PM | #20 |
34
Rep 280
well the reason i ask is that i just brought my car to the dealer today for a top off of 1 quart as requested by the idrive.
After the fill up it read one tick below max. I guess I am one of the lucky ones? It did however take over an hour for the computer to re-read the level. It just kept showing the clock. I was looking to see if anyone knew how that sensor worked.
2003 Ducati '996
04-01-2009, 05:19 PM | #21 |
108
Rep 1,291
it was fine after dealership took care of it. I have 14000kms and already had to do the "Add 1L" twice. You mentioned that you brought your car to dealership for that? Did they charge you for that? Because it cost me $18 for 1 L of motor oil when I added it myself.
Must stop eating..............
