11-03-2008, 07:22 AM | #3 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Try calling TCKline. I talked to TC about a month ago. He said he was happy with his design, so they should be out any time now.
11-03-2008, 12:58 PM | #4 |
137
Rep 304
11-03-2008, 01:11 PM | #5 |
98
Rep 1,043
why do you guys want them?
have yall crawled up underneath the car and looked at how difficult it would be the change the bars? no way in hell im doing it.... |
11-03-2008, 04:02 PM | #8 |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
if the e92 M3 is similar to my e90 sway bar install it looks a little frigthening looking at the stuff that needs to be removed to include the exhaust etc.
One tuner shop gave me a 4 hr labor cost for my e90 325i. but with some local gas station mechanic ingenuity he was able to do it in 2 hrs. If the M3 is similar in desggn, this job most likely involves dropping the subframe. but the trick to all this was dropping the frame by loosening 4 long frame attachment bolts. Keeping it still connected to the car upper body frame is the key and just loosening the bolts out at about 3 inches. Eniough to get some wiggle roon to maneuver the sway bar out. BUT STILL ATTACHED TO THE CAR. Once about three inches in dropped, you can then remove the rear wheels and slighty get the rotors out of the way. So you can feed the sway bar out and in from the wheel wells. (after of crse loosening the mount clamps. Thats how it was done on my e90. but for safety, the car has to be jacked up on the lift using the 4 point frame method, leaving the rear wheel axle hanging BUT supported by another aligator jack at the rear differential case unit.
11-03-2008, 04:10 PM | #9 |
//Mdicted
347
Rep 9,988
can anyone pls post the PN of the Sway Bar and if its not to expensive, maybe I can find the same mechanic that did my e90 and maybe post good DYI photos
11-03-2008, 04:55 PM | #10 |
125
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
My M3 came with sway/roll bars as standard equipment.
I'm curious why folks think the roll bars need to be stiffer?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
11-03-2008, 04:58 PM | #11 | |
832
Rep 46,029
IMHO the car as is is flat enough, but hey, people earn easy money i guess jk |
11-03-2008, 05:06 PM | #13 | |
125
Rep 3,071
I agree, the car is quite flat in corners, I love the suspension as it came from the factory. Supple enough for long trips yet stiff enough for weekend track work.
11-03-2008, 05:07 PM | #14 |
832
Rep 46,029
yah it's one of the best handling cars, but there's plenty of room for improvement.... i only realized that after seeing the video of Enzo and those super cars on the track where the M3 was tailing them as a safety car. it just looked so wobbly and soft compared to those
11-06-2008, 10:37 AM | #17 |
137
Rep 304
Well, if i was cruising in the neighborhood i prob wouldn't. but on the track even with the springs, it could use less roll.
