Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Limited Power/Revs When Cold ?
      10-29-2008, 08:34 AM   #1
CrimsonRedE93
CrimsonRedE93's Avatar
108
Drives: Le Mans Blue E93 330d+
I had never noticed that the car would either limit te revs/power when it was cold until this morning when I went to pull out and not a lot happened.
The car seemed to be limitng the revs to about 2500rpm and had reduced power, It was really wierd the more you put your foot further down and the revs stayed at the same level.
I presume this is normal and it was only as my car had not warmed up due to the chilly morning?
      10-29-2008, 09:12 AM   #2
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
948
Drives: 997.2 GT3
They dont limit power when cold. I have never thrashed my car from but bar once which i had to for an emergency, No limiting of power.
M cars have the illuminated dash to remind you not to thrash tyo high revs from cold.
Non M cars can be doughnutted off your driveway at 6am if needed be.
997.2 GT3
      10-29-2008, 10:00 AM   #3
MOB
MOB's Avatar
England
56
Drives: Alpine White M2 LCI
Could it have just been the traction control limiting power?
      10-29-2008, 10:00 AM   #4
booforty
booforty's Avatar
337
Drives: E92 M3
2008 E92 M3  [0.00]
Carl, I hope no one doughnuts their car off the driveway in the morning!!
Sounds like somethings up as limiting to 2.5k revs is not normal...
      10-29-2008, 11:32 AM   #5
Budgie
Budgie's Avatar
England
30
Drives: X1 25D M sport
MAF failure? Could limit the reving or breathing of the engine. Any VW owner will tell you this is a common failure
      10-29-2008, 11:46 AM   #6
M3-FAST
Defected to the dark side.....
M3-FAST's Avatar
England
210
Drives: BMW M5 LCi
Mine has been doing exactly the same for a while now. It does it every morning, and if the car has not been driven during the day, every evening when leaving work.
It almost feels as though it is running a couple of cylinders short. I keep meaning to book it in the garage, but my dealer is so sh!te, I just know it will end up coming back with more faults Either that or they will claim 'no fault found!' like they have with every other problem I have taken the car in with!
I suspected on mine it could be a problem with the injectors, as I know the 325i has had an injector re-call. Mine has not been in to have it done yet.
When/If you find out the answer I will be interested to know!
      10-29-2008, 12:20 PM   #7
XKaLiBaR
XKaLiBaR's Avatar
17
Drives: M3
Why are you guys revving the FANDANGO out of your cars when cold!!!!
Mods ListAP Racing BBKs, Bilstein PSS10 , Rogue Engineering Pulleys, RTM and Transmission Mounts, Eibach ARBs, Supersprint LightWeight Race Muffler, Miltek 100 Cell Cats, Recaro Pole Positions, Aluminium Brushed Trim, Csl Steering wheel, Imola Red Arm Rest, CSL Diffuser, 10mm Eibach Spacers, Depo Indicators, Custom blacked out front grills, Carbon Fibre Side Grills, Custom UUC ClutchStop, CSL OEM Bootlid, V-CSL Bumper,
      10-29-2008, 12:23 PM   #8
dbramley
320d M-Sport
England
88
Drives: BMW 320si
Is that not a 'limp home' mode, i.e it limits your rev's / engine work so no futher damage can be done?
My Mondy ST used to go in limp home mode all the time, usually when something was broke but then it was a bag of sh...!
Previous: BMW 320si E90 Le Mans Blue. | BMW 320d E92 LCI Alpine White | F10 520d Alpine White
Now: F30 320d X-Drive Alpine White
      10-29-2008, 12:33 PM   #9
greatbm
greatbm's Avatar
148
Drives: G15 840i Coupe
2 x recalls for injectors
G15, 840i M Sport
      10-29-2008, 12:39 PM   #10
SixDegrees
SixDegrees's Avatar
12
Drives: M135i
2011 Abarth 500  [0.00]
Aye, factory fitted option with VAG... the MAF Failure!
2014 [14] M135i, 3dr, MG, Auto, SP, CP, HS, HK and FBP
Recent Past.....
2011 [61] Abarth 500, Funk White, Leather, H&R
2007 [57] 320d M-Sport Touring
Pre 2007 - GT TDI 4MO, Mk4 R32, A3 TQ, A3T, Cupra R and on and on and on.....
      10-29-2008, 01:41 PM   #11
dxb335d
dxb335d's Avatar
England
948
Drives: 997.2 GT3
I dont thrash my car from cold. its only ever happened once. Because i had to.
It could be a form of limp home mode, but why would it happen in the morning when cold? either that or what brian said, MAF sensor failure?
Does it clear once warm?
997.2 GT3
      10-29-2008, 04:08 PM   #12
CrimsonRedE93
108
I only noticed it because there is a roundabout thats really busy about half a mile from my house and I tried to pull out as normal and it felt really flat so i tried putting accelerating when doing 30 and the car acted oddly by not letting the revs build.
I left work tonight and tried the same cold and it felt flat, I gave it a run for 15 min to make sure it was really warm and it seems to be normal.
I am sure it was not the DTC/DSC I know what that feels like
Thanks for your comments guys, I will keep an eye on it
      10-29-2008, 05:09 PM   #13
Speedtrap
57
Drives: A very fast car :)
Never happened mate...revving it past 2.5k is quite common in the morning to et away from traffic for me. Better have it checked out; could be a problem on the Vanos. Had a problem with with my old M3 with the same problem, and had to replace one of the inlet solenoid. Could be something as simple as plugs...
      10-29-2008, 05:15 PM   #14
M3-FAST
M3-FAST's Avatar
England
210
Drives: BMW M5 LCi
It is not like I am trying to rev it. It is a strange feeling. The car is holding back, like being starved of fuel or similar? Where it would normally pull away cleanly and rev through first and into second, it holds back and then all of a sudden releases the power and drives normally again.
It does it every day now and most evenings if it is parked outside work and not driven during the day.
You can literally floor it in first gear and it would hold the revs right down and give about 20% power, and by the time I have driven to the end of my estate, it releases the power instantly and then drives normally?!
stange beast!
      10-30-2008, 08:22 AM   #15
CrimsonRedE93
108
Sound's like a quote from the book of Fandango
      10-30-2008, 08:32 AM   #16
biscuits
Dimmer than a dim thing
biscuits's Avatar
80
Drives: M4 GTS, EQC, X5 40d, simrig
I never go over 3k and half throttle till the oil/water temp is up to normal in any of my cars, never have...... oh unless it's a rental car, they have specially uprated engines that mean they can be redlined from cold
      10-30-2008, 06:39 PM   #17
335DJim
335DJim's Avatar
Drives: 335D Coupe
Amen brother!
