04-24-2021, 03:42 PM | #1 |
Capable
Rep 111
N55: Spun hub, YAY
Hello all,
I thought this was only a S55 issue, but after my car made a PFFF after getting on it, (luckily no metal rattling or oil everywhere) I was rewarded with alot of codes and the car turning off. Used an endoscope and it appears i have the smallest amount of valve to piston contact. Pictures coming. I am asking for recommendations on fixing this. I started by rotating the crank at the hub to see if it was seized completely or still rotated (which is when i was able to spin the crank bolt a few times before the engine started to turn over). the engine rotated and the pistons look fine which gives me a little hope that perhaps a valve or two is bent and the fix is not as bad as it could be. Here is my current issue. I need to time the car again to check for compression but i have a singlemass spec flywheel. I just purchased the tool for aligning cams and vanos, and the pins to hold the crank in place but not sure if this flywheel is going to have the timing holes I need. My question is: could i time this any other way or am i going to need to drop the transmission and put on an OE flywheel? For checking compression i think i can ball park it, but ultimately would i think im going to need to find a DMFW since i threw mine away a few years back not thinking this would be an issue. I have a new DKM dual disc organic, but do not think those have timing marks either. Here are the codes i recieved: 165011 165012 165013 165014 130f11 130e11 120408 164021 164031 |
04-24-2021, 03:47 PM | #2 |
Capable
Rep 111
https://drive.google.com/drive/folde...p4N6dxdmKA4Yzv
here's a few photos of the pistons where you can see valve contact, and the codes I was rewarded with. |
04-24-2021, 04:41 PM | #3 | |
485
Rep 1,105
What year and mileage on the car?
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
madrrio9.00 |
04-24-2021, 05:17 PM | #4 |
Capable
Rep 111
2013, 75k.
N55 running ps2, e85 (w port injection kit), full bolt ons and tuned. Think one of the extra injectors started getting leaky, as I was having wot issues wheree the car would sputter or break up. I been trying to diagnose w data logs n switching things out (spark plugs, coils, I jectors was next). I ran the car after swapping the coils n though I had fixed the issue but then did a 4th gear pull down a hill to reduce load and the issue arrised. |
04-25-2021, 10:37 AM | #5 |
442
Rep 1,121
Drives: 2015 BMW 435i Xdrive MSport
I've never heard of this happening on the N55.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
04-25-2021, 01:31 PM | #6 |
Capable
Rep 111
04-27-2021, 07:03 PM | #9 |
468
Rep 1,348
Happened to mines miss shift 2k15 335xdrive 6 speed . Spun crank bent valves, then spun bearings since oil pump stopped spinning. Bolt was also loose.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
madrrio9.00 |
04-27-2021, 07:57 PM | #10 |
Capable
Rep 111
04-28-2021, 05:34 PM | #11 |
@lbb_kev
494
Rep 516
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage Last edited by -Eidos; 04-29-2021 at 01:41 PM.. |
F32Fleet3606.00 |
04-29-2021, 01:42 AM | #12 |
1086
Rep 2,363
Auch PWG? If you are and not running JB4 then I am very interested in seeing some of your logs
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
04-29-2021, 03:01 AM | #13 |
Capable
Rep 111
05-02-2021, 02:41 AM | #14 |
1086
Rep 2,363
Who did the tuning?
(A Dane in China) |
05-03-2021, 10:46 AM | #15 |
Capable
Rep 111
Cary, the car has always ran perfectly fine for the past 2 years or so. i think the recent issues i was facing originated form a leaking injector on the PI rail. I had ordered a new set, but after swapping in the OE coils i thought i had fixed it as it was pulling like it use to.
05-05-2021, 01:35 AM | #16 | |
1086
Rep 2,363
(A Dane in China) |
12-01-2021, 12:58 AM | #18 |
Capable
Rep 111
So an update. Been forever but got the motor and started taking things apart. One connecting rod has a super small bend. Finally got the crank out and it looks like the thrust bearing failed. See photos... It ate right into the damn crank.
I doubt they cN weld and machine where the material is missing, so I'll probably be looking for a replacement. Getting a motor swapped directly might be a better option and then I'll sell my ps2 and all the bells and whistles. |
