04-18-2021, 10:09 PM | #1 |
151
Rep 171
Front Center Jackpoint
My quick jack even with an extension won't fit the G05 side jack points. Was wondering if anyhow knows if there is a center jack point in front of the car so I can jack up and use the side ones with jack stands.
04-19-2021, 11:38 AM | #2 | |
472
Rep 1,294
So Which quickjack do you have? I have the BL7000 EXT. It was ok for my E71, but will not fit between the jack points for the F96. Easy fix, you will need to use it across the frame, left side to right side. No problem it was designed to do this and quickjack confirmed this. I have used it this way several times and there is absolutely no stability issues. I hope this helps.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
04-19-2021, 10:24 PM | #3 |
151
Rep 171
I have the BL-5000SLX. It has 60 inch spread. I think there is an extension to get it to 66 inch spread which is equal to your 7000 lift. So I'm assuming 66 inches allows you to fit the jack from side to side?
04-19-2021, 11:37 PM | #4 | |
472
Rep 1,294
Yes it allows me to fit side to side with a few inches to spare. I think the L/R spread is about 62-63". As you can see I also use the truck adapters.
