04-09-2021, 02:01 PM | #1 |
Rep 8
About to buy a 435d Pre LCI - Does the facelift matter after upgrades?
Hi F30Post,
Just moved this to the UK forum as I think it was in the wrong place before. From what I gather from reading other posts is most of the LCI changes can be retrofitted however steering and suspension are a bit more difficult. Disregarding a retrofit I want to ask if a suspension upgrade on a Pre LCI 435d with xDrive and M Adaptive Suspension can ever be better or equal than one on an LCI BMW. If I understand things correctly it shouldn't make a difference as the car can be modded to whatever feels right. Although the Pre LCI car is old it is super low mileage and has some incredible options that you cant find on newer (used) F36s. Any and all advice is highly appreciated as I am about to shoot the shot on this car. £22k - BMW AUC 2015 with 20k miles - Citrine Black, Merino Leather, Extended leather (ind.), Sunroof, Adaptive Suspension, M brakes and calipers, HK Sound, Heads Up, LED Adaptive, High Beam Assist, Reversing Camera, Surround Camera, ACC, Heated Wheel, Indv. Piano Black --- Haven't seen a better specced 4 series at this price and mileage. 1) Can a pre LCI car be made to have better or equal handling and suspension to a post LCI car? 2) What would it take to do the above on an xDrive car with Adaptive Suspension (without losing the stock adaptive damper option)? 2.1) Am considering B16 Adaptive Dampers and Front and Rear ARBs at the moment. Anything else? Thanks! |
04-09-2021, 02:18 PM | #2 |
2472
Rep 4,653
Not sure about the differences but unless you're doing track days don't reckon you would notice the difference between the two when doing daily driving.
You'd be better fitting a set of coilovers rather than retro fitting LCI OEM suspension.
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
04-09-2021, 03:06 PM | #3 | |
559
Rep 1,502
Drives: F36 435xd
Wow....As you describe it with color and specs, it could be my Car. I got ACS springs on mine but Will go for a KW DDC kit. Prob later this year. You would prob not know the difference in dd
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
04-09-2021, 04:08 PM | #4 | ||
Rep 8
What made you go with the KW DDC ones. Do they work with the EDC? |
04-09-2021, 04:13 PM | #5 | |||
559
Rep 1,502
Drives: F36 435xd
And it was good. But didn't last long. Aprox. 80.000km. Then the front dampers was gone. I have a friend with active KW's and he is very pleased with them. So I thought I'd give them a try. And yes they work with EDC, plug and play
Brgds
04-09-2021, 05:29 PM | #7 |
Barge driver
8664
Rep 12,429
https://usedcars.bmw.co.uk/vehicle/2...f-8b969ba210fd
This one I guess, sounds a lovely car great spec, Lloyds are a good dealer group in my experience as well, as for the mods get the car drive it see what you think after a few months and adapt as you wish, as there are always trade offs when modding a car.
730d/Z4C
04-09-2021, 06:03 PM | #9 | |
715
Rep 1,161
Diesel BMWs like to be driven and should be given that performance! Armaan |
04-09-2021, 06:17 PM | #10 |
2259
Rep 2,050
I think that depends if it's only been used for short town journeys, or parked up a lot and used for fewer longer journeys. I looked at an '11 FFRR with 50k on it just before buying the 3 and it was a farmer's 'nice' car - he used the farm Fourtrak for any short stuff and the FFRR only did longer trips. Similarly for short journeys with my ex we'd always use her Fabia and my cars would be used on longer journeys. I totally take the point though that it's difficult to know unless you actually speak to the original owner.
Rathian155.00 |
04-10-2021, 01:54 AM | #11 | |
715
Rep 1,161
04-10-2021, 08:30 AM | #13 | |||
Rep 8
Do you have any idea what to look for in the test drive to identify future issues? |
Rathian155.00 |
04-10-2021, 04:20 PM | #14 | |
309
Rep 649
However, I think you'll find that the 435Xd doesn't have "M" suspension , adaptive or not. All 435Xd's of the period had the standard floaty ("Luxury model") suspension, 10mm higher than the MSport set up and seriously underdamped. I had this std. set up on my pre-LCI June '15 330Xd. ACS springs helped a bit but couldn't negate the fundamental sogginess and sluggish/heavy turn in/body roll, until the outside tyre suddenly says "OK, I've got it". My son has this car now and the difference twixt his and my std. adaptive Sdrive 440i is quite remarkable. Summary The spec. is awesome, just spend a couple £k's on the suspension and you'll be smiling from here to eternity. Cheers Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
04-11-2021, 01:59 AM | #15 |
72
Rep 182
The LCI had the following changes:
New Chassis setup for significantly improved steering, braking and handling New, stiffer Front Strut Towers New Rear Damper Technology New Electric power steering Enhanced Steptronic Automatic Transmission 5 Suspension Anchor Points vs. 3 |
04-11-2021, 05:57 AM | #16 | ||||
715
Rep 1,161
It's pretty much a catch 22 as above - has it been used for longer journeys or shorter? No idea. Has the first or second driver done such low mileage because it's just used to pop to do the weekly shop or longer weekend travel? No idea. That's the risk with dealer sale and I don't think there is any real tell tale sign, you'll just encounter problems down the line, but who knows to what extent... Personally I'd not buy a 6 year old diesel with 20k on the clock without knowing more about the history. Armaan |
