E92 335i with E93 M3 Subframe/diff
04-07-2021, 07:08 AM | #1 |
Rep 15
Hey folks,
I just mounted a complete E93 M3 rear end into my 335i. As this is becoming a more common swap of late, I was wondering if we could list out the torque specs for the following items: - Prop shaft/giubo to transmission output (2 x 3) - prop shaft to diff input which I believe are E14 or E18 (6) - subframe mounting bolts E20 (4) - axle nuts 12 point 36mm (1-7/16 works!) (2) - ALL control arms...two bolts on each end so probably 10-14 in total - Top and bottom of rear shocks (I used 3 series coilovers and lower control arms because I could and I had them If there’s anything else you can think of back there I’m open to suggestions. This has been an exciting and challenging build. In the past 365 days I’ve thrown about $13,000 at this car and it’s really starting to come together. Please follow my YouTube highspoolteacher or Instagram @high.spool.teacher for the full updates.
Atlantic Blue E92 6 speed, tuned by David Shoup
- XSPower 17t eBay hybrid turbos with eBay FBO - Bilstein B14 coilovers, 034Motorsport M3 control arms, TMS camber plates, Eibach front sway bar, M3 E93 rear end conversion, ? Subframe bushings UNDECIDED lol |
Tags |
control arms, m3 conversion, subframe, torque specs |
