10-27-2008, 04:19 AM | #1 |
yodog
197
Rep 5,026
How's the ride/handling on the H&R's?
Guys, how has the ride/handling changed since you install your H&R Sport Springs? Do you guys notice the rebound a bit dead? Or does it still feel like the suspension is working in optimal condition like stock?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
10-27-2008, 01:09 PM | #2 |
57
Rep 1,798
Installed H & R Sports (there is a race version as well) - With my EDC off, I feel that there is less roll, and less rebound. Wiith EDC, its fantastic and the ride is firmer/harder. Always love H & Rs
10-27-2008, 05:00 PM | #3 |
yodog
197
Rep 5,026
Improved handling.. hmm I'm just afraid the handling might be worse
10-27-2008, 05:02 PM | #4 |
832
Rep 46,029
the car will be jumpy like a motherfucker. i was watching how longtran's car was bouncing in front of me on the freeway the other day. reminded me of the crappy H&R springs i had on my 335
never again |
10-27-2008, 05:20 PM | #5 |
85
Rep 425
Car feels closest to factory ride than on other cars that I've installed only lowering springs. The car retains it's handling with the added benefit of decreased roll as Speedtrap stated since the springs follow the linear design of the stock pieces. I was actually surprised H&R didn't use a more increased rate. The pros are prolonged shock life and ride comfort but at a cost of ground clearance under compression. The felt covered pieces under the front bumper are getting frayed from scraping. I don't have problems with bouncing and it even smoothed out that pogo effect I had on deep compressions.
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick 2016 Agate Grey GT4 PCCB LWB 2013 HP4 Competition |
10-27-2008, 05:30 PM | #6 |
135
Rep 1,825
ive seen both the eibach's and h and r's and the eibach's are def. a bit smoother. My friend just installed the eibach's and his ride is exactly like factory only less roll and slightly lower.
10-27-2008, 05:35 PM | #7 |
85
Rep 425
The thing I don't like about the Eibach springs is that one side is progressive. I can't remember if it's the front or back.
I'm sure there are a good amount of folks with both setups in your area. Just set up a drive so you can feel them for yourself. Allen
10-27-2008, 05:50 PM | #8 |
1429
Rep 16,628
it wasnt bouncing. you crazy man. its stiff than a mofo when you have edc on. its solid with the springs. i'd stay away from the h&r race springs though.
10-27-2008, 06:08 PM | #9 |
475
Rep 13,583
Drives: JB E92 335i
I've heard great things about H&R springs on the new M3s. I would highly recommend it. If you want to go above and beyond, you can always go with the KW V3 coilovers!
10-27-2008, 06:12 PM | #10 | |
832
Rep 46,029
not that bad, but definitely bounced more, dont tell me u didnt expect that though! |
10-27-2008, 08:03 PM | #11 |
M4 CSL FBG
1268
Rep 1,871
No problems for me, still rides great.
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World 08' E92 M3 Jerez Black |
10-29-2008, 12:33 AM | #13 |
85
Rep 425
Springs are a DIY if you've done your fair share of wrenching. The only special tools required are MacPherson strut type spring compressors which you should be able to rent for free. Search for the DIY in the e90post section. Otherwise, I'd expect about 2.5 hours of labor.
Allen
10-29-2008, 03:58 AM | #14 |
yodog
197
Rep 5,026
I was quoted $400 from evosport... or could go with Long Tran.
10-29-2008, 03:10 PM | #15 |
19
Rep 186
I've had no problems so far. Feels planted and handles great...it would be subjective to state if the handling is better or the same, but it hugs corners unbelieveably. I do not feel it is "bouncy", but the most important test it passed= the wife test. She falls asleep in the car all the time without a complaint, so that is the most important test. Perfect stance btw....always kinda bothered me that the M3 sat a bit tall and the 335's have a better stock stance...now it looks perfect.
10-29-2008, 06:28 PM | #16 |
69
Rep 628
10-30-2008, 12:57 PM | #17 |
137
Rep 304
My experience was that at high speeds the car feels a little less stable, kinda hovering over the road, not as precise as with the stocks. I dont know if that is for real or just my imagination. noticed it after i took her to the track. First with the stock springs and 3 days later with the H&Rs and now i wish i changed to coilovers.
But it looks great though i have to give them that. |
10-30-2008, 01:03 PM | #18 |
85
Rep 425
Get an alignment and try again.
Allen
10-30-2008, 01:25 PM | #19 |
137
Rep 304
10-30-2008, 02:42 PM | #20 | |
n1smo
97
Rep 1,483
Drives: E92 M3
10-31-2008, 03:45 AM | #21 |
63
Rep 2,427
ride is good with the H&Rs. However, I too was surprised that H&R didn't make these springs stiffer. they feel maybe only about 15% stiffer than stock. I would have actually liked a stiffer spring. it feels too soft over speed bumps and driveways. I had H&Rs on my '03 Mini S, and those were pretty stiff.
but back to the M, i guess it's the perfect balance between looks, handling, and ride
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
10-31-2008, 07:29 PM | #22 |
2277
Rep 12,994
