prelci headlight modification, can I use lci turn signal? Also, painting help?!
04-03-2021, 11:56 PM | #1 |
Rep 9
hello all,
I've gone through search after google, after search and have yet to see anyone use the LCI turn signal module in the pre lci headlight housing. I'm looking to find out if this can be done? is there a specific bracket that holds the module in place or can I fix the piece to the housing? I'd love to try it out, but cannot find anything about it. thanks for any info if any exists! ALSO, I see so many modified headlights with painted projector caps with colors and that's fantastic, they all look great once they're freshly done, but my question is....how does that paint hold up over time? Does anyone have problems with the bulbs' heat causing the paint to boil or peel? btw, I have the bi-xenon adaptive headlight on pre-lci e90 sedan. thanks!
2007 BMW 328xi
04-16-2021, 05:24 PM | #2 | |
ASCMA General
51
Rep 157
04-21-2021, 02:31 PM | #3 |
765
Rep 3,558
The LCI adaptive internal shroud has an outboard trim piece that the turn signal assy attaches to. The backof the turn signal assy also screws (3X) to the headlight housing. The trim piece I mentioned at first has the many holes in it that the individual turn signal lights poke in through. You would have to try to adapt this trim piece. I would buy a junk LCI adaptive housing to get one as well as learn how it's all put together. I'll find a picture of this trim piece and post it.
