BMW X5
      04-03-2021, 08:02 AM   #1
Eagle-NestIT
Netherlands
Drives: BMW 520 Tour / X5 ordered
X5 45e stage 2 tuning experience?
I saw this movie and was wondering if anyone did a stage 2 tuning on his X5 45e?
Appreciate 2
      04-10-2021, 12:00 PM   #2
Wzon
13
Drives: BMW X5 G05
Nope,
Only stage 1 with airfilter from KN
Gave me 530hk and 820NM I don't want to change the cat and exhaust. That certainly voids the warranty.
This ones I can do a rollback on 😎
Appreciate 2
      04-10-2021, 05:39 PM   #3
Eagle-NestIT
Netherlands
Is there a big difference before and after tuning?
      10-13-2021, 05:41 AM   #4
januza
60
Drives: X5 45e
I have stage 1 with down pipes and exhaust on mine. Stage 2 requires a bit more modification as turbo pressure increases from 1.3 bar to 1.6 bar.
I have dyno results at 556whp / 783nm.
Stage 2 will give additional 50-60hp.
      10-13-2021, 03:44 PM   #5
dananelson1
dananelson1's Avatar
226
Drives: 22 X5 45e, 13 X5xdrive50i SOLD
I've wondered what a stock 45e has in the way of turbo boost? Is 1.3BAR? That seems high (I come with a longstanding thought that 12-15PSI is acceptable for LT reliability - below is better and Higher is riskier LT) considering the 45e has been detuned from the 40i given the extra E power.....I can't find good info on the details here for stock turbo boost?
      11-01-2021, 11:41 PM   #6
Mrdonbonjovi
23
Drives: 328i xDrive
Which tune do you have? Interested to hear the setup and if there are any places people are discussing tuning options on the 45e.
Tried google searching with old posts.
      11-02-2021, 12:06 AM   #7
januza
60
Drives: X5 45e
Custom DME tune with down pipes and custom exhaust.
      11-02-2021, 08:46 AM   #8
kingmonkeyjr
455
Drives: X3M40i, GLC63, E63s, Trackhawk
I am doing what I always do .. JB4 ! That 4psi over stock always does the trick for me and super easy to install and take off when service is calling.
russell21147.00
      11-02-2021, 08:48 AM   #9
kingmonkeyjr
455
Given that it's the B58 if I recall on the X3M40i it was boosting up in the mid 20's. Stock it is around 17-19psi.
      06-08-2022, 05:28 AM   #10
zezinhom400
Drives: M5 F10; E46 323i; X5 45e
You guys with the Stage 1: was there any impact in the seamlessness of transition from battery to motor? Is it any more interruptive than stock? Sound more intrusive? Not a bad thing, just interested in knowing what changes other than the power itself thx
      06-17-2022, 06:30 PM   #11
2Slow.
2Slow.'s Avatar
32
Drives: X5 Xdrive45e, M135I
Can we create short list of validated tuners for xdrive45e?
I read from above:
DME (custom)
Who else?
Would be interested to have thermal camera reading of engine, intercoolers and exhaust side after and before tune post dyno run...
      06-23-2022, 08:42 PM   #12
januza
60
Drives: X5 45e
I read from above:
DME (custom)
Who else?
DME is like ECU tune its not a tuner.
      06-06-2023, 08:46 AM   #13
roomesrco
Drives: 2012 VW Amarok
This is my plan as well with a good filter. What is your output after that?
xbimmers
