BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Anyone use spacers on XI?
      10-26-2008, 03:12 PM   #1
Save Bluth
24
Drives: non-Beemer (for now)
Are any of you running spacers on the rear for more of a "flush" look? If so, what size? And, any issues specific to the XI using these things? Thanks.
'13 335i M-Sport l Glacier Silver l Black l AlumHex l 8AT
retired: '08 335 xi l Silver/Black/Gray Pop l KW v3 l 6AT
retired: '01 Z3 2.5i l Silver l Black l 5MT
retired: '94 325is l Black l Black l 5MT
      10-26-2008, 03:31 PM   #2
Ph0zenstone
Ph0zenstone's Avatar
324
Drives: 2018 530e X-Drive
Here are 12mm H&R Spacers on my E92 Xi. no problems at all. Probably could have fit 15mm but might rub with fat chicks in the back
      10-26-2008, 03:53 PM   #3
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
15mm spacers up front with the OEM ZCP rims and no problems at all
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      10-26-2008, 04:31 PM   #4
Save Bluth
24
Thanks for the responses so far. For those that use spacers, do you use them in front and rear? Or, is it more common to use them just in rear?
      10-26-2008, 06:24 PM   #5
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I use them up front w/o problems. I use Rogue Engineering 15mm spacers with their bolts.
      10-26-2008, 09:50 PM   #6
goldtl
goldtl's Avatar
Drives: 08 e92 335xi
i have 1 1/4 inch spacers on the rear for my winter setup (17x7.5 +35 all around) dropped on KW v3...it rubs a little so im going to raise up the car half an cm or so...im waiting for my front spacers (20mm) to arrive...without the spacers, the car looks too funny. Now it has a more aggressive stance.
      10-28-2008, 09:18 PM   #7
jgalaxy
Gearing
jgalaxy's Avatar
86
Drives: E46 M3, F22 M240
No vibrations being heard from the spacers at all? I cant remeber where I read about someone that ran into that trouble ....
If at first you don't succeed ...
      10-28-2008, 09:40 PM   #8
Doc E
Surf Caster Extraordinaire
Doc E's Avatar
Ukraine
30
Drives: '13 ISF
Rogue spacers FTW! quality is top notch and its also easy to get them off if they rust onto the hub.
335i gone!
      10-29-2008, 07:43 AM   #9
nyc3r
nyc3r's Avatar
112
Drives: E90
I would get them but then I'm not sure if I can find wheel locks..
      10-29-2008, 10:45 AM   #10
Save Bluth
24
wheels locks with spacers
Are wheel locks suggested/required if using spacers?
      10-29-2008, 07:04 PM   #11
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
You can use wheel locks, but follow the guidelines published by Rogue Engineering.
      10-29-2008, 08:12 PM   #12
GregL
GregL's Avatar
98
Drives: 2016 CLA45 AMG
+1. Rogue provides the part numbers for McGard locks so there's no way to go wrong.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone
2010 Mercedes-Benz C350 4Matic - Gone
2006 BMW 330xi - Gone
2001 Infiniti QX4 - Gone
      10-29-2008, 09:35 PM   #13
Ph0zenstone
324
i believe RAD makes extended locks for use with spacers. they are like $40-50 for a set.
      10-30-2008, 10:43 PM   #14
chinoxs203
chinoxs203's Avatar
122
Drives: 08 E92 335xi AW
link to purchase spacers? i may want some for my rears now that i gotta put my 189s back on for winter they will look like their far inside the wheel wells now that i am lower.
what size you think for the rears?
FOR SALE:
Dropbox - please
      10-30-2008, 10:48 PM   #15
Ph0zenstone
324
12mm was perfect for my wheels without rubbing. check my pics several posts up.
      10-31-2008, 07:08 PM   #16
GregL
GregL's Avatar
98
I've been meaning to get spacers for my winter set, they're 17x8" ET37 which are even worse than oem. However I've been concerned about how handling and turning will affected with a wider rear track (vs front), do any of you find that things are in any way "off" by having spacers only at the back? I'm looking at either 15 or 18mm from Rogue.
      11-02-2008, 10:11 PM   #17
Ph0zenstone
324
i didn't feel it driving any different to be honest. but thats just daily driving, no track use so i can't say for sure that you would feel no difference either.
      11-03-2008, 11:15 AM   #18
GregL
GregL's Avatar
98
Fair enough, but what about tight turning situations like backing into a parking space?
      11-03-2008, 01:38 PM   #19
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I haven't been able to feel much difference with the 15mm front spacers that I have.
      11-03-2008, 08:30 PM   #20
Ph0zenstone
324
yeh no difference with turning and parking either, any difference you feel is probably similar to the infamous butt dyno
      11-03-2008, 09:14 PM   #21
GregL
GregL's Avatar
98
Alright, thanks for the input guys!
      11-03-2008, 10:07 PM   #22
PKumarM3
Air India
India
145
Drives: 2018 Dodge Durango
Compared to H&R spacers, rogue spacers are absolute shit.
Just compare the quality between H&R spacers next to Rogue Spacers.
I had the Rogue 10mm spacers on the rear of my E46 M3 (i run a 18x9.5 square set up ET35) and the spacer just was stuck on. I used copper anti-seize and cleaned up the hub before putting the spacer on. They are garbage.
The H&R spacer looks much better made and also is easy to put on and take off (space available in the middle to use to pull off.
I don't really require the extended bolts since I have a stud kit on the E46 M3 and plan on putting one on the E90 as well - makes wheel swaps much easier.
I have a spare set of 12mm spacers that I plan on putting on the rear of my car when the time comes. Just need to order a set of studs from Turner Motorsports.
PKumarM3
Search this Thread:
Advanced Search
