TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 2011 E90 Msport wheel fitment for 193 rims
      03-27-2021, 07:13 PM   #1
DougNBodie
DougNBodie's Avatar
27
Drives: BMW 335d M Sport
2011 BMW 335d  [10.00]
Anyone know if I can put 235/40/18 on the front and 265/35/18 on the back? Tires rack is confusing as it give conflicting info.
Stock E90 with M Sport package (sport suspension) and 193 rims 8.5 front and 9.5 back
Thanks
      03-27-2021, 07:46 PM   #2
dmatre
674
Drives: 2011 328i Sedan
They will fit without rubbing, as long as you don't use spacers - otherwise the rears may rub.
      03-28-2021, 02:52 AM   #3
Fritzer
No one sleep in Tokyo
Fritzer's Avatar
No_Country
945
Drives: 2011 E90 328i//1995 E34 530i
Thanks
Generally a good rule of thumb is +/- 10mm from OEM tire sizes, on the OEM wheels. Sometimes you can push it, I wouldn't. I run those exact tire specs on Style 197 wheels, which came as M-Sport wheels. 18x8 ET34/18x8.5 ET37. Zero issues whatsoever. Use bmwstylewheels.com to lookup exact wheel specs. Then there are some good charts that I'm sure you could find online which essentially show you what the biggest tire size you can run on certain width wheels, and the corresponding aspect ratio needed.(the second number in a tire size)
The largest tire on a non-M3 E9x that I've ever seen actually fit without issues, was 285mm on a 335is. And the owner of that car had rubbing issues on high suspension compression scenarios. Biggest you could fit without rubbing would probably be 275mm. I have a picture somewhere of a light blue E92 Dinan M3 with 335mm tires on the rear that I saw at my local little cars and coffee.
t. someone who used to live and breath rubber for a living
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
      03-28-2021, 02:56 AM   #4
Fritzer
Fritzer's Avatar
No_Country
945
By the way, your style 193s are the exact same specs as my 197s. (18x8 and 18x8.5) The off-setting of the wheels as well.
      04-13-2021, 03:55 AM   #5
DougNBodie
DougNBodie's Avatar
27
Thank you for the information.
