02-03-2021, 12:35 PM | #1 |
Rep 7
M2C carbon front grille fitting
Just picked by my M2C in Sunset Orange last week and loving it so far!
It was a dealer demo with a great spec, including the carbon fibre M Performance parts. I have noticed, however, that one side of the front grille isn't sitting flush, where the other side is. I have given it a push, to see if it just needs clicking in, but no joy. Rather than going through the hassle of getting the dealer to sort it (which is made even harder during lockdown!) I wondered if anyone had a guide on how to fit these? Been looking around and found plenty for the original M2, but not the Comp. Any tips would be appreciated. Thanks in advance! |
02-03-2021, 01:44 PM | #2 |
31
Rep 39
From: https://f87.bimmerpost.com/forums/sh....php?t=1701278
1. Remove rubber strip covering the front fascia T30 torx screws. 2. Remove six T30 Torx. 3. Pull fascia forward (it's very pliable) and slip hand in. 4. Locate top plastic tabs along grill and push those in and forward while you pull on grille from outside with other hand. (This takes some patience and going back and forth between tabs). 5. While pulling up and out with external hand, push in tabs along bottom of grille. It takes a bit of patience first time you do it. After one time however it becomes a lot easier. |
02-03-2021, 02:10 PM | #3 | |
Rep 7
02-03-2021, 04:00 PM | #4 |
305
Rep 138
At least for myself, I couldn't get my hands inside the fascia after removing the torx screws. I guess I was too scared to bend it out. I don't know if it's easier with the OG M2. I was able to fit my hands between the grille slats. Undo all the center tabs first so the center pops out. The two tabs on each end are the hardest. I used a 90 degree pry tool to pop those out. Once you get one end loose you can pull the grille away and reach for the other end. I've done this twice now and sitting on a stool in front of the bumper was the most comfortable. You might have a broken tab which could cause it not to sit flush.
02-06-2021, 04:45 AM | #5 | |
Rep 7
02-07-2021, 12:18 AM | #6 | |
305
Rep 138
02-08-2021, 05:14 AM | #7 | |
Rep 7
Overall I'm loving the car so far (collected 10 days ago), not that I've had much chance to use it yet! |
