01-27-2021, 02:36 PM | #1 |
Rep 3
LED headlights won't turn off. Any solution?
Has anyone had an issue with your headlights being stuck "on" when it's on the "off" position? I went through the whole set of switch positions but my LED headlights will not turn off at all. It's normally on auto, but they are stuck on with every setting.
This just started after I was trying to put the fog lights on and noticed they weren't coming on. Anyone have any ideas on what's wrong? |
01-27-2021, 02:39 PM | #2 |
4367
Rep 7,613
This might be a dumb question, but are you sure its the headlights and not the daytime running lights setting in idrive?
Also, staying on while the car is off/locked, or on while the ignition is on but switch is in off position? |
01-27-2021, 03:11 PM | #3 |
Rep 3
Yep, just double checked everything in iDrive. Thankfully, the lights turn off while off/locked. BUT, the headlights are on in auxiliary power and I now see & hear that they are making a VERY odd high pitched noise under the hood... now it's showing I'm having battery drain.
01-27-2021, 04:11 PM | #4 | |
4367
Rep 7,613
